Name | Synopsis | Description | Return Values | Errors | Files | Attributes | See Also
cc [ flag… ] file… -lkstat [ library… ] #include <kstat.h> kid_t kstat_read(kstat_ctl_t *kc, kstat_t *ksp, void *buf);
kid_t kstat_write(kstat_ctl_t *kc, kstat_t *ksp, void *buf);
The kstat_read() function gets data from the kernel for the kstat pointed to by ksp. The ksp->ks_data field is automatically allocated (or reallocated) to be large enough to hold all of the data. The ksp->ks_ndata field is set to the number of data fields, ksp->ks_data_size is set to the total size of the data, and ksp->ks_snaptime is set to the high-resolution time at which the data snapshot was taken. If buf is non-null, the data is copied from ksp->ks_data to buf.
The kstat_write() function writes data from buf, or from ksp->ks_data if buf is NULL, to the corresponding kstat in the kernel. Only the superuser can use kstat_write().
Upon successful completion, kstat_read() and kstat_write() return the current kstat chain ID (KCID). Otherwise, they return -1 and set errno to indicate the error.
The kstat_read() and kstat_write() functions will fail if:
An attempt was made to write to a non-writable kstat.
The kstat was temporarily unavailable for reading or writing.
An attempt was made to write data to a kstat, but the number of elements or the data size does not match.
Insufficient storage space is available.
The given kstat could not be located for reading or writing.
The data for the given kstat was too large to be stored in the structure.
An attempt was made to write to a kstat, but {PRIV_SYS_CONFIG} was not asserted in the effective privilege set.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Stable |
MT-Level |
Unsafe |
kstat(3KSTAT), kstat_chain_update(3KSTAT), kstat_lookup(3KSTAT), kstat_open(3KSTAT), attributes(5), privileges(5)
