Name | Synopsis | Parameters | Description | Return Values | Attributes | See Also
cc [ flag… ] file… -lMPAPI [ library… ] #include <mpapi.h> MP_STATUS MP_EnableAutoProbing(MP_OID oid);
The MP_EnableAutoProbing() function enables auto-probing.
The oid parameter does not specify any valid object type . This is most likely to happen if an uninitialized object ID is passed to the API.
The oid parameter has a type subfield other than MP_OBJE CT_TYPE_PLUGIN or MP_OBJECT_TYPE_MULTIPATH_LU.
The oid parameter owner ID or object sequence number is invalid.
The operation is successful.
The API is not supported.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: ANSI INCITS 412 Multipath Management API |
MT-Level |
Safe |
libMPAPI(3LIB), MP_DisableAutoProbing(3MPAPI), attributes(5)
Multipath Management API Version 1.0
