Name | Synopsis | Parameters | Description | Return Values | Attributes | See Also
cc [ flag… ] file… -lMPAPI [ library… ]
#include <mpapi.h>
MP_STATUS MP_GetAssociatedPathOidList(
MP_OID oid, MP_OID MP_OID_LIST **ppList);
The object ID of the multipath logical unit, initiator port, or target port.
A pointer to a pointer to an object ID that has type MP_OID_LIST structure. With a successful return, this will contain a pointer to an object ID that has type MP_OID_LIST that contains the object IDs of all the paths associated with the specified (multipath) logical unit, initiator port, or target port oid.
The MP_GetAssociatedPathOidList() function gets a list of oid object IDs for all the path logica l units associated with the specified multipath logical unit , initiator port, or target port.
Returns a list of object IDs for all the path logical units associated with the specified mult ipath logical unit, initiator port, or target port.
When the caller is finished using the list it must free the memory used by the list by calling MP_FreeOidList.
The ppList is null or specifies a memory area to that the data cannot be written or when the oid has a type subfield other than MP_OBJECT_TYPE_MULTI PATH_LU, MP_OBJECT_TYPE_INITIATOR_PORT, or MP_OBJECT_TYPE_TARGET_PORT.
The oid does not specify any valid object type. This is most likely to happen if an uninitialized object ID is passed to the API.
The oid owner ID or object sequence number is invalid.
The operation is successful.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: ANSI INCITS 412 Multipath Management API |
MT-Level |
Safe |
libMPAPI(3LIB), MP_GetPathLogicalUnitProperties(3MPAPI), attributes(5)
Multipath Management API Version 1.0
