Name | Synopsis | Parameters | Description | Return Values | Attributes | See Also
cc [ flag… ] file… -lMPAPI [ library… ] #include <mpapi.h> MP_STATUS MP_GetAssociatedTPGOidList(MP_OID oid, MP_OID_LIST **ppList);
The object ID of the multipath logical unit.
A pointer to a pointer to an object ID that has type MP_OID_LIST structure. With a successful return, this will contain a pointer to an object ID that has type MP_OID_LIST that contains the object IDs of target port groups associated with the specified logical unit.
The MP_GetAssociatedTPGOidList() function gets a list of the object IDs containing the target port group associated with the specified multipath logical unit.
When the caller is finished using the list, it must free the memory used by the list by calling MP_FreeOidList.
The oid does not specify any valid object type. This is most likely to happen if an uninitialized object ID is passed to the API.
The ppList is null or specifies a memory area to which data cannot be written, or the oid has a type subfield other than MP_OBJECT_TYPE_MULTIPATH_LU.
The oid owner ID or object sequence number is invalid.
The operation is successful.
The target port group list for the specified object ID is not found.
A memory allocation failure occurred.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: ANSI INCITS 412 Multipath Management API |
MT-Level |
Safe |
libMPAPI(3LIB), MP_GetTargetPortGroupProperties(3MPAPI), attributes(5)
Multipath Management API Version 1.0
