Name | Synopsis | Parameters | Description | Return Values | Attributes | See Also
cc [ flag… ] file… -lMPAPI [ library… ]
#include <mpapi.h>
MP_STATUS MP_GetInitiatorPortOidList(MP_OID oid,
MP_OID_LIST **ppList);
The object ID of the plugin.
A pointer to a pointer to an object ID that has type MP_OID_LIST structure. With a successful return, this contains a pointer to anMP_OID_LIST that contains the object IDs of all the initiator ports associated with the specified plugin.
The MP_GetInitiatorPortOidList() function gets a list of the object IDs of all the initiator ports associated with this plugin. When the caller is finished using the list it must free the memory used by the list by calling MP_FreeOidList.
The oid does not specify any valid object type. This is most likely to happen if an uninitialized object ID is passed to the API.
The pplist is null or specifies a memory area to which data cannot be written, or when the oid has a type subfield other than MP_OBJECT_TYPE_PLUGIN.
The oid owner ID or object sequence number is invalid.
The operation is successful.
A memory allocation failure occurred.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: ANSI INCITS 412 Multipath Management API |
MT-Level |
Safe |
libMPAPI(3LIB), MP_GetInitiatorPortProperties(3MPAPI), attributes(5)
Multipath Management API Version 1.0
