Name | Synopsis | Parameters | Description | Return Values | Attributes | See Also
cc [ flag… ] file… -lMPAPI [ library… ] #include <mpapi.h> MP_STATUS MP_GetMPLuOidListFromTPG(MP_OID oid, MP_OID_LIST **ppList);
The object ID of the target port group.
A pointer to a pointer to an object ID that has type MP_OID_LIST structure. With a successful return, this contains a pointer to an object ID that has type MP_OID_LIST that contains the object IDs of all the (multipath) logical units associated with the specified target port group.
The MP_GetMPLuOidListFromTPG() function returns the list of object IDs for the multipath logical units associated with the specific target port group.
When the caller is finished using the list, it must free the memory used by the list by calling MP_FreeOidList.
The oid does not specify any valid object type. This is most likely to happen if an uninitialized object ID is passed to the API.
The pplist is null or specifies a memory area to which data cannot be written, or when the oid has a type subfield other than MP_OBJECT_TYPE_TARGET_PORT.
The oid owner ID or object sequence number is invalid.
The operation is successful.
The multipath logical unit list for the specified target port group object ID is not found.
A memory allocation failure occurred.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: ANSI INCITS 412 Multipath Management API |
MT-Level |
Safe |
libMPAPI(3LIB), MP_GetMPLogicalUnitProperties(3MPAPI), attributes(5)
Multipath Management API Version 1.0
