Name | Synopsis | Parameters | Description | Return Values | Attributes | See Also
cc [ flag… ] file… -lMPAPI [ library… ] #include <mpapi.h> MP_STATUS MP_GetPluginOidList(MP_OID_LIST **ppList);
A pointer to a pointer to an object ID that has type MP_OID_LIST. With a successful return, this contains a pointer to an object ID that has type MP_OID_LIST that contains the object IDs of all of the plugins currently loaded by the library.
The MP_GetPluginOidList() function returns a list of the object IDs of all currently loaded plugins. The returned list is guaranteed to not contain any duplicate entries.
When the caller is finished using the list it must free the memory used by the list by calling MP_FreeOidList(3MPAPI).
The ppList is null or specifies a memory area to which data cannot be written.
The operation is successful.
The plugin for the specified object ID is not found.
A memory allocation failure occurred.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: ANSI INCITS 412 Multipath Management API |
MT-Level |
Safe |
libMPAPI(3LIB), MP_FreeOidList(3MPAPI), MP_GetPluginProperties(3MPAPI), attributes(5)
Multipath Management API Version 1.0
