Name | Synopsis | Parameters | Description | Return Values | Attributes | See Also
cc [ flag… ] file… -lMPAPI [ library… ]
#include <mpapi.h>
MP_STATUS MP_GetTargetPortProperties(MP_OID oid,
MP_TARGET_PORT_GROUP_PROPERTIES *pProps);
The object ID of the target port group.
A pointer to an object ID that has type MP_TARGET_PORT_GROUP_PROPERTIES structure allocated by the caller. With a successful return, this structure contains the properties of the target port group specified by the oid.
The MP_GetTargetPortProperties() function returns the properties of the specified target port.
The pProps is null or specifies a memory area to which data cannot be written or when the oid has a type subfield other than MP_OBJECT_TYPE_TARGET_PORT.
The oid does not specify any valid object type. This is most likely to happen if an uninitialized object ID is passed to the API.
The oid owner ID or object sequence number is invalid.
The operation is successful.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: ANSI INCITS 412 Multipath Management API |
MT-Level |
Safe |
libMPAPI(3LIB), MP_GetTargetPortOidList(3MPAPI), attributes(5)
Multipath Management API Version 1.0
