Name | Synopsis | Parameters | Description | Return Values | Attributes | See Also
cc [ flag… ] file… -lMPAPI [ library… ]
#include <mpapi.h>
MP_STATUS MP_RegisterForObjectPropertyChanges(
MP_OBJECT_PROPERTY_FN pClientFn, MP_OBJECT_TYPE objectType,
void *pCallerData, MP_OID pluginOid);
A pointer to an object ID that has type MP_OBJECT_PROPERTY_FN function defined by the client. With a successful return, this function is called to inform the client of objects that have had one or more properties changed.
The type of object the client wishes to register for property change callbacks.
A pointer that is passed to the callback routine with each event. This might be used by the caller to correlate the event to the source of the registration.
If this is a valid plugin object ID, then registration is limited to that plugin. If this is zero, then the registration is for all plugins.
The MP_RegisterForObjectPropertyChanges() function registers a client function to be called whenever the property of an object changes.
The function specified by pClientFn is called whenever the property of an object changes. For the purposes of this function, a property is defined to be a field in an object's property structure and the object's status. Therefore, the client function is not called if a statistic of the associated object changes. But, it is called when the status changes (e.g., from working to failed) or when a name or other field in a property structure changes.
It is not an error to re-register a client function. However, a client function has only one registration. The first call to deregister a client function will deregister it no matter how many calls to register the function have been made.
If multiple properties of an object change simultaneously, a client function can be called only once to be notified that all the changes have occurred.
The pluginOid or objectType does not specify any valid object type. This is most likely to happen if an uninitialized object ID is passed to the API.
The pluginOid owner ID or object sequence number is invalid.
The pCallerData is null or if the pluginOid has a type subfield other than MP_OBJECT_TYPE_PLUGIN, or when objectType is invalid.
The operation is successful.
An existing client function is replaced with the one specified in pClientFn.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard: ANSI INCITS 412 Multipath Management API |
MT-Level |
Safe |
libMPAPI(3LIB), MP_DeregisterForObjectPropertyChanges(3MPAPI), attributes(5)
Multipath Management API Version 1.0
