Name | Synopsis | Parameters | Description | Return Values | Errors | Attributes | See Also | Notes
cc [flag...] file... -lX11 -lXtsol [library...] #include <X11/extensions/Xtsol.h> Status XTSOLgetPropAttributes(display, window, property, propattrp); Display *display; Window window; Atom property; XTSOLPropAttributes *propattrp;
Specifies a pointer to the Display structure; returned from XOpenDisplay().
Specifies the ID of a window system object.
Specifies the property atom.
Client must provide a pointer to XTSOLPropAttributes.
The client requires the PRIV_WIN_DAC_READ and PRIV_WIN_MAC_READ privileges. The XTSOLgetPropAttributes() function retrieves the label attributes that are associated with a property hanging out of a window in a single call. The attributes include UID and sensitivity label.
None
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
MT-Unsafe |
libXtsol(3LIB), XTSOLgetClientAttributes(3XTSOL), XTSOLgetResAttributes(3XTSOL), attributes(5)
Setting Window Polyinstantiation Information in Solaris Trusted Extensions Developer’s Guide
The functionality described on this manual page is available only if the system is configured with Trusted Extensions.
