Name | Synopsis | Parameters | Description | Return Values | Errors | Attributes | See Also | Notes
cc [flag...] file... -lX11 -lXtsol [library...] #include <X11/extensions/Xtsol.h> Status XTSOLgetSSHeight(display, screen_num, newheight); Display *display; int screen_num; int *newheight;
Specifies a pointer to the Display structure; returned from XOpenDisplay().
Specifies the screen number.
Specifies the storage area where the height of the stripe in pixels is returned.
The XTSOLgetSSHeight() function gets the height of trusted screen stripe at the bottom of the screen. Currently the screen stripe is only present on the default screen. Client must have the Trusted Path process attribute.
None.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
Unsafe |
libXtsol(3LIB), XTSOLsetSSHeight(3XTSOL), attributes(5)
Accessing and Setting the Screen Stripe Height in Solaris Trusted Extensions Developer’s Guide
The functionality described on this manual page is available only if the system is configured with Trusted Extensions.
