Name | Synopsis | Parameters | Description | Return Values | Errors | Attributes | See Also | Notes
cc [flag...] file... -lX11 -lXtsol [library...] #include <X11/extensions/Xtsol.h> Status XTSOLsetResLabel(display, object, type, sl); Display *display; XID object; ResourceType type; m_label_t *sl;
Specifies a pointer to the Display structure; returned from XOpenDisplay().
Specifies the ID of a window system object whose label you want to change. Possible window system objects are windows and pixmaps.
Specifies what type of resource is being accessed. Possible values are IsWindow and IsPixmap.
Specifies a pointer to a sensitivity label.
The client must have the PRIV_WIN_DAC_WRITE, PRIV_WIN_MAC_WRITE, PRIV_WIN_UPGRADE_SL, and PRIV_WIN_DOWNGRADE_SL privileges. The XTSOLsetResLabel() function changes the label that is associated with a window or a pixmap.
None.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
MT-Level |
Unsafe |
libXtsol(3LIB), XTSOLgetResAttributes(3XTSOL), XTSOLgetResLabel(3XTSOL), attributes(5)
Setting a Window Label in Solaris Trusted Extensions Developer’s Guide
The functionality described on this manual page is available only if the system is configured with Trusted Extensions.
