Name | Synopsis | Description | Attributes | See Also
#include <dirent.h>
The internal format of directories is unspecified. The <dirent.h> header defines the following type:
A type representing a directory stream.
The header also defines the structure dirent, which includes the following members:
ino_t d_ino /* file serial number */ char d_name[] /* name of entry */
The type ino_t is defined as described in <sys/types.h>. See types(3HEAD).
The character array d_name is of unspecified size, but the number of bytes preceding the terminating null byte must not exceed {NAME_MAX}.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Standard |
closedir(3C), opendir(3C), readdir(3C), rewinddir(3C), seekdir(3C), telldir(3C), types.h(3HEAD), attributes(5), standards(5)
