Name | Synopsis | Description | INTERFACES | Files | Attributes | See Also
cc [ flag... ] file... -lnsl [ library... ]
Functions in this library provide routines that provide a transport-level interface to networking services for applications, facilities for machine-independent data representation, a remote procedure call mechanism, and other networking services useful for application programs.
Some symbols are not intended to be referenced directly. Rather, they are exposed because they are used elsewhere through a private interface. One such example is the set of symbols beginning with the _xti prefix. Those symbols are used in implementing the X/Open Transport Interface (XTI) interfaces documented in libxnet. See libxnet(3LIB).
The shared object libnsl.so.1 provides the public interfaces defined below. See Intro(3) for additional information on shared object interfaces.
__rpc_createerr |
__t_errno |
_nderror |
_null_auth |
_xti_accept |
_xti_alloc |
_xti_bind |
_xti_close |
_xti_connect |
_xti_error |
_xti_free |
_xti_getinfo |
_xti_getprotaddr |
_xti_getstate |
_xti_listen |
_xti_look |
_xti_open |
_xti_optmgmt |
_xti_rcv |
_xti_rcvconnect |
_xti_rcvdis |
_xti_rcvrel |
_xti_rcvreldata |
_xti_rcvudata |
_xti_rcvuderr |
_xti_rcvv |
_xti_rcvvudata |
_xti_snd |
_xti_snddis |
_xti_sndrel |
_xti_sndreldata |
_xti_sndudata |
_xti_sndv |
_xti_sndvudata |
_xti_strerror |
_xti_sync |
_xti_sysconf |
_xti_unbind |
_xti_xns5_accept |
_xti_xns5_snd |
auth_destroy |
authdes_create |
authdes_getucred |
authdes_lock |
authdes_seccreate |
authnone_create |
authsys_create |
authsys_create_default |
callrpc |
clnt_broadcast |
clnt_call |
clnt_control |
clnt_create |
clnt_create_timed |
clnt_create_vers |
clnt_create_vers_timed |
clnt_destroy |
clnt_dg_create |
clnt_door_create |
clnt_freeres |
clnt_geterr |
clnt_pcreateerror |
clnt_perrno |
clnt_perror |
clnt_raw_create |
clnt_spcreateerror |
clnt_sperrno |
clnt_sperror |
clnt_tli_create |
clnt_tp_create |
clnt_tp_create_timed |
clnt_vc_create |
clntraw_create |
clnttcp_create |
clntudp_bufcreate |
clntudp_create |
dbmclose |
dbminit |
delete |
des_setparity |
dial |
doconfig |
endhostent |
endnetconfig |
endnetpath |
endrpcent |
fetch |
firstkey |
freehostent |
freenetconfigent |
get_myaddress |
gethostbyaddr |
gethostbyaddr_r |
gethostbyname |
gethostbyname_r |
gethostent |
gethostent_r |
getipnodebyaddr |
getipnodebyname |
getipsecalgbyname |
getipsecalgbynum |
getipsecprotobyname |
getipsecprotobynum |
getnetconfig |
getnetconfigent |
getnetname |
getnetpath |
getpublickey |
getrpcbyname |
getrpcbyname_r |
getrpcbynumber |
getrpcbynumber_r |
getrpcent |
getrpcent_r |
getrpcport |
getsecretkey |
h_errno |
host2netname |
inet_addr |
inet_netof |
inet_ntoa |
inet_ntoa_r |
inet_ntop |
inet_pton |
key_decryptsession |
key_encryptsession |
key_gendes |
key_secretkey_is_set |
key_setsecret |
maxbno |
nc_perror |
nc_sperror |
netdir_free |
netdir_getbyaddr |
netdir_getbyname |
netdir_options |
netdir_perror |
netdir_sperror |
netname2host |
netname2user |
nextkey |
nis_add |
nis_add_entry |
nis_addmember |
nis_checkpoint |
nis_clone_object |
nis_creategroup |
nis_data |
nis_destroy_object |
nis_destroygroup |
nis_dir_cmp |
nis_domain_of |
nis_dump |
nis_dumplog |
nis_find_item |
nis_finddirectory |
nis_first_entry |
nis_free_request |
nis_freenames |
nis_freeresult |
nis_freeservlist |
nis_freetags |
nis_get_request |
nis_get_static_storage |
nis_getnames |
nis_getservlist |
nis_in_table |
nis_insert_item |
nis_insert_name |
nis_ismember |
nis_leaf_of |
nis_leaf_of_r |
nis_lerror |
nis_list |
nis_local_directory |
nis_local_group |
nis_local_host |
nis_local_principal |
nis_lookup |
nis_make_error |
nis_make_rpchandle |
nis_mkdir |
nis_modify |
nis_modify_entry |
nis_name_of |
nis_next_entry |
nis_perror |
nis_ping |
nis_print_directory |
nis_print_entry |
nis_print_group |
nis_print_group_entry |
nis_print_link |
nis_print_object |
nis_print_rights |
nis_print_table |
nis_read_obj |
nis_remove |
nis_remove_entry |
nis_remove_item |
nis_remove_name |
nis_removemember |
nis_rmdir |
nis_servstate |
nis_sperrno |
nis_sperror |
nis_sperror_r |
nis_stats |
nis_verifygroup |
nis_write_obj |
pmap_getmaps |
pmap_getport |
pmap_rmtcall |
pmap_set |
pmap_unset |
registerrpc |
rpc_broadcast |
rpc_broadcast_exp |
rpc_call |
rpc_control |
rpc_createerr |
rpc_gss_get_error |
rpc_gss_get_mech_info |
rpc_gss_get_mechanisms |
rpc_gss_get_principal_name |
rpc_gss_get_versions |
rpc_gss_getcred |
rpc_gss_is_installed |
rpc_gss_max_data_length |
rpc_gss_mech_to_oid |
rpc_gss_qop_to_num |
rpc_gss_seccreate |
rpc_gss_set_callback |
rpc_gss_set_defaults |
rpc_gss_set_svc_name |
rpc_gss_svc_max_data_length |
rpc_reg |
rpcb_getaddr |
rpcb_getmaps |
rpcb_gettime |
rpcb_rmtcall |
rpcb_set |
rpcb_unset |
sethostent |
setnetconfig |
setnetpath |
setrpcent |
store |
svc_auth_reg |
svc_control |
svc_create |
svc_destroy |
svc_dg_create |
svc_dg_enablecache |
svc_done |
svc_door_create |
svc_exit |
svc_fd_create |
svc_fdset |
svc_freeargs |
svc_get_local_cred |
svc_getargs |
svc_getreq |
svc_getreq_common |
svc_getreq_poll |
svc_getreqset |
svc_getrpccaller |
svc_max_pollfd |
svc_pollfd |
svc_raw_create |
svc_reg |
svc_register |
svc_run |
svc_sendreply |
svc_tli_create |
svc_tp_create |
svc_unreg |
svc_unregister |
svc_vc_create |
svcerr_auth |
svcerr_decode |
svcerr_noproc |
svcerr_noprog |
svcerr_progvers |
svcerr_systemerr |
svcerr_weakauth |
svcfd_create |
svcraw_create |
svctcp_create |
svcudp_bufcreate |
svcudp_create |
t_accept |
t_alloc |
t_bind |
t_close |
t_connect |
t_errno |
t_error |
t_free |
t_getinfo |
t_getname |
t_getstate |
t_listen |
t_look |
t_nerr |
t_open |
t_optmgmt |
t_rcv |
t_rcvconnect |
t_rcvdis |
t_rcvrel |
t_rcvudata |
t_rcvuderr |
t_snd |
t_snddis |
t_sndrel |
t_sndudata |
t_strerror |
t_sync |
t_unbind |
taddr2uaddr |
uaddr2taddr |
undial |
user2netname |
xdr_accepted_reply |
xdr_array |
xdr_authsys_parms |
xdr_bool |
xdr_bytes |
xdr_callhdr |
xdr_callmsg |
xdr_char |
xdr_destroy |
xdr_double |
xdr_enum |
xdr_float |
xdr_free |
xdr_getpos |
xdr_hyper |
xdr_inline |
xdr_int |
xdr_int16_t |
xdr_int32_t |
xdr_int64_t |
xdr_int8_t |
xdr_long |
xdr_longlong_t |
xdr_opaque |
xdr_opaque_auth |
xdr_pointer |
xdr_quadruple |
xdr_reference |
xdr_rejected_reply |
xdr_replymsg |
xdr_setpos |
xdr_short |
xdr_sizeof |
xdr_string |
xdr_u_char |
xdr_u_hyper |
xdr_u_int |
xdr_u_long |
xdr_u_longlong_t |
xdr_u_short |
xdr_uint16_t |
xdr_uint32_t |
xdr_uint64_t |
xdr_uint8_t |
xdr_union |
xdr_vector |
xdr_void |
xdr_wrapstring |
xdrmem_create |
xdrrec_create |
xdrrec_endofrecord |
xdrrec_eof |
xdrrec_readbytes |
xdrrec_skiprecord |
xdrstdio_create |
xprt_register |
xprt_unregister |
yp_all |
yp_bind |
yp_first |
yp_get_default_domain |
yp_master |
yp_match |
yp_next |
yp_order |
yp_unbind |
yp_update |
yperr_string |
ypprot_err |
The following interface is unique to the 32-bit version of this library:
_new_svc_fdset |
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWcsl (32–bit) |
SUNWcslx (64–bit) |
MT-Level |
Safe with exceptions |
