Name | Synopsis | Description | Interfaces | Files | Attributes | See Also
cc [ flag… ] file… -lpapi [ library… ] #include <papi.h>
Functions in this library provide an interface for interaction with print services as described in v1.0 of the Free Standards Group (FSG) Open Printing API (PAPI).
This particular implementation of the PAPI includes naming support as described in the printers.conf(4) and printers(4) manual pages. It also supplies support for interaction with local LP services, remote LPD services, and remote IPP services through the use of loadable modules that export the same interface. These modules should not be linked with directly, but can be used directly at runtime through the use of LD_PRELOAD for debugging purposes.
The shared object libpapi.so.0 provides the public interfaces defined below. See Intro(3) for additional information on shared object interfaces.
papiAttributeListAddBoolean |
papiAttributeListAddCollection |
papiAttributeListAddDatetime |
papiAttributeListAddInteger |
papiAttributeListAddMetadata |
papiAttributeListAddRange |
papiAttributeListAddResolution |
papiAttributeListAddString |
papiAttributeListAddValue |
papiAttributeListDelete |
papiAttributeListFind |
papiAttributeListFree |
papiAttributeListFromString |
papiAttributeListGetBoolean |
papiAttributeListGetCollection |
papiAttributeListGetDatetime |
papiAttributeListGetInteger |
papiAttributeListGetMetadata |
papiAttributeListGetNext |
papiAttributeListGetRange |
papiAttributeListGetResolution |
papiAttributeListGetString |
papiAttributeListGetValue |
papiAttributeListToString |
papiServiceCreate |
papiServiceDestroy |
papiServiceGetAppData |
papiServiceGetAttributeList |
papiServiceGetEncryption |
papiServiceGetPassword |
papiServiceGetServiceName |
papiServiceGetStatusMessage |
papiServiceGetUserName |
papiServiceSetAppData |
papiServiceSetAuthCB |
papiServiceSetEncryption |
papiServiceSetPassword |
papiServiceSetUserName |
papiPrinterAdd |
papiPrinterDisable |
papiPrinterEnable |
papiPrinterFree |
papiPrinterGetAttributeList |
papiPrinterListFree |
papiPrinterListJobs |
papiPrinterModify |
papiPrinterPause |
papiPrinterPurgeJobs |
papiPrinterQuery |
papiPrinterRemove |
papiPrinterResume |
papiPrintersList |
papiJobCancel |
papiJobFree |
papiJobGetAttributeList |
papiJobGetId |
papiJobGetJobTicket |
papiJobGetPrinterName |
papiJobHold |
papiJobListFree |
papiJobModify |
papiJobMove |
papiJobPromote |
papiJobQuery |
papiJobRelease |
papiJobRestart |
papiJobStreamClose |
papiJobStreamOpen |
papiJobStreamWrite |
papiJobSubmit |
papiJobSubmitByReference |
papiJobValidate |
shared object
private shared code
private rfc1179 support
private LP support
private IPP support
private IPP marshalling support
private IPP operations support
private HTTP support
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWpapi |
Interface Stability |
Volatile |
MT-Level |
Safe |
