Name | Synopsis | Description | INTERFACES | Files | Attributes | See Also | Notes
cc [ flag... ] file.. -ltnfctl [ library... ] #include <tnf/tnfctl.h>
Functions in this library provide TNF probe control routines for use by processes and the kernel.
The shared object libtnfctl.so.1 provides the public interfaces defined below. See Intro(3) for additional information on shared object interfaces.
tnfctl_buffer_alloc |
tnfctl_buffer_dealloc |
tnfctl_check_libs |
tnfctl_close |
tnfctl_continue |
tnfctl_exec_open |
tnfctl_filter_list_add |
tnfctl_filter_list_delete |
tnfctl_filter_list_get |
tnfctl_filter_state_set |
tnfctl_indirect_open |
tnfctl_internal_open |
tnfctl_kernel_open |
tnfctl_pid_open |
tnfctl_probe_apply |
tnfctl_probe_apply_ids |
tnfctl_probe_connect |
tnfctl_probe_disable |
tnfctl_probe_disconnect_all |
tnfctl_probe_enable |
tnfctl_probe_state_get |
tnfctl_probe_trace |
tnfctl_probe_untrace |
tnfctl_register_funcs |
tnfctl_strerror |
tnfctl_trace_attrs_get |
tnfctl_trace_state_set |
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWtnfc (32–bit) |
SUNWtnfcx (64–bit) |
MT-Level |
MT-Safe with exceptions |
This API is MT-Safe. Multiple threads can concurrently operate on independent tnfctl handles, which is the typical behavior expected. libtnfctl does not support multiple threads operating on the same tnfctl handle. If this is desired, it is the client's responsibility to implement locking to ensure that two threads that use the same tnfctl handle are not simultaneously present in a libtnfctl interface.
