Name | Synopsis | Description | Files | See Also
/system/contract/process
Process contracts allow processes to create a fault boundary around a set of subprocesses and observe events which occur within that boundary.
Process contracts are managed using the contract(4) file system and the libcontract(3LIB) library. The process contract type directory is /system/contract/process.
A process contract is created when an LWP that has an active process contract template calls fork(2). Initially, the child process created by fork() is the only resource managed by the contract. When an LWP that does not have an active process contract template calls fork(), the child process created by fork() is added as a resource to the process contract of which the parent was a member.
The following events types are defined:
The last member of the process contract exited.
A new process has been added to the process contract.
A member of the process contract exited.
A process failed and dumped core. This could also occur if the process would have dumped core had appropriate coreadm(1M) options been enabled and core file size was unlimited.
A process received a fatal signal from a process, other than the owner of the process contract, that is a member of a different process contract.
A process was killed because of an uncorrectable hardware error.
The following common contract terms, defined in contract(4), have process-contract specific attributes:
The default value for the informative event set is (CT_PR_EV_CORE | CT_PR_EV_SIGNAL).
The default value for the critical event set is (CT_PR_EV_EMPTY | CT_PR_EV_HWERR).
An attempt by a user without the {PRIV_CONTRACT_EVENT} privilege in its effective set to add an event, other than CT_PR_EV_EMPTY, to the critical event set which is not present in the fatal set, or if the CT_PR_PGONLY parameter is set and the same user attempts to add any event, other than CT_PR_EV_EMPTY, to the critical event set, fails.
The following contract terms can be read from or written to a process contract template using the named libcontract(3LIB) interfaces. These contract terms are in addition to those described in contract(4).
Defines a set of events which, when generated, causes all members of the process contract to be killed with SIGKILL, or the intersection of the contract and the containing process group if the CT_PR_PGRPONLY parameter is set. Set this term with ct_pr_tmpl_set_fatal(3CONTRACT). The fatal event set is restricted to CT_PR_EV_CORE, CT_PR_EV_SIGNAL, and CT_PR_EV_HWERR. For CT_PR_EV_CORE and CT_PR_EV_SIGNAL events, the scope of SIGKILL is limited to those processes which the contract author or the event source could have normally sent signals to.
The default value for the fatal event set is CT_PR_EV_HWERR.
If a user without the {PRIV_CONTRACT_EVENT} privilege in its effective set removes an event from the fatal event set which is present in the critical event set, the corresponding event is automatically removed from the critical event set and added to the informative event set.
Defines miscellaneous other settings. Use ct_pr_tmpl_set_param(3CONTRACT) to set this term.
The default parameter set is empty.
The value is a bit vector comprised of some or all of:
If set, indicates that the process contract is to be inherited by the process contract the contract owner is a member of if the contract owner exits before explicitly abandoning the process contract.
If not set, the process contract is automatically abandoned when the owner exits.
If set, all processes in a process contract are sent SIGKILL if the process contract is abandoned, either explicitly or because the holder died and CT_PR_INHERIT was not set. The scope of SIGKILL is limited to those processes which the contract author or the event source could have normally sent signals to.
If this is not set and the process contract is abandoned, the process contract is orphaned, that is, continues to exist without owner.
If set, only those processes within the same process group and process contract as a fatal error-generating process are killed.
If not set, all processes within the process contract are killed if a member process encounters an error specified in the fatal set.
If a user without the {PRIV_CONTRACT_EVENT} privilege in its effective set adds CT_PR_PGRPONLY to a template's parameter set, any events other than CT_PR_EV_EMPTY are automatically removed from the critical event set and added to the informative event set.
If set, the process contract can inherit unabandoned contracts left by exiting member processes.
If not set, indicates that the process contract should not inherit contracts from member processes. If a process exits before abandoning a contract it owns and is a member of a process contract which does not have CT_PR_REGENT set, the system automatically abandons the contract.
If a regent process contract has inherited contracts and is abandoned by its owner, its inherited contracts are abandoned.
Specifies the ID of an empty process contract held by the caller whose inherited process contracts are to be transferred to the newly created contract. Use ct_pr_tmpl_set_transfer(3CONTRACT) to set the tranfer contract. Attempts to specify a contract not held by the calling process, or a contract which still has processes in it, fail.
The default transfer term is 0, that is, no contract.
In addition to the standard items, the status object read from a status file descriptor contains the following items if CTD_FIXED is specified:
Values equal to the terms used when the contract was written. Use
ct_pr_status_get_fatal(3contract) ct_pr_status_get_param(3contract) |
to obtain this information. respectively.
If CTD_ALL is specified, the following items are also available:
The PIDs of processes which are members of the process contract. Use ct_pr_status_get_members(3CONTRACT) to obtain this information.
The IDs of contracts which have been inherited by the process contract. Use ct_pr_status_get_contracts(3CONTRACT) to obtain this information.
The following standard status items have different meanings in some situations:
If the process contract has a state of CTS_OWNED or CTS_INHERITED and is held by an entity in the global zone, but contains processes in a non-global zone, it appears to have the state CTS_OWNED when observed by processes in the non-global zone.
If the process contract has a state of CTS_OWNED or CTS_INHERITED and is held by an entity in the global zone, but contains processes in a non-global zone, it appears to be held by the non-global zone's zsched when observed by processes in the non-global zone.
In addition to the standard items, an event generated by a process contract contains the following information:
The process ID of the member process which experienced the event, or caused the contract event to be generated (in the case of CT_PR_EV_EMPTY). Use ct_pr_event_get_pid(3CONTRACT) to obtain this information.
If the event type is CT_PR_EV_FORK, the event contains:
The process ID which forked [Generating PID]. Use ct_pr_event_get_ppid(3CONTRACT) to obtain this information.
If the event type is CT_PR_EV_EXIT, the event contains:
The exit status of the process. Use ct_pr_event_get_exitstatus(3CONTRACT) to obtain this information.
If the event type is CT_PR_EV_CORE, the event can contain:
The name of the per-process core file. Use ct_pr_event_get_pcorefile(3CONTRACT) to obtain this information.
The name of the process's zone's global core file. Use ct_pr_event_get_gcorefile(3CONTRACT) to obtain this information.
The name of the system-wide core file in the global zone. Use ct_pr_event_get_zcorefile(3contract) to obtain this information.
See coreadm(1M) for more information about per-process, global, and system-wide core files.
If the event type is CT_PR_EV_SIGNAL, the event contains:
The number of the signal which killed the process. Use ct_pr_event_get_signal(3CONTRACT) to obtain this information.
It can contain:
The PID of the process which sent the signal. Use ct_pr_event_get_sender(3CONTRACT) to obtain this information.
ctrun(1), ctstat(1), ctwatch(1), coreadm(1M), close(2), fork(2), ioctl(2), open(2), poll(2), ct_pr_event_get_exitstatus(3CONTRACT), ct_pr_event_get_gcorefile(3CONTRACT), ct_pr_event_get_pcorefile(3CONTRACT), ct_pr_event_get_pid(3CONTRACT), ct_pr_event_get_ppid(3CONTRACT), ct_pr_event_get_signal(3CONTRACT), ct_pr_status_get_contracts(3CONTRACT), ct_pr_status_get_members(3CONTRACT), ct_pr_tmpl_set_fatal(3CONTRACT), ct_pr_tmpl_set_param(3CONTRACT), ct_pr_tmpl_set_transfer(3CONTRACT), ct_tmpl_set_cookie(3CONTRACT), ct_tmpl_set_critical(3CONTRACT), ct_tmpl_set_informative(3CONTRACT), libcontract(3LIB), contract(4), privileges(5)
