Name | Description | Examples | See Also
The file /etc/vfstab describes defaults for each file system. The information is stored in a table with the following column headings:
device device mount FS fsck mount mount to mount to fsck point type pass at boot options |
The fields in the table are space-separated and show the resource name (device to mount), the raw device to fsck (device to fsck), the default mount directory (mount point), the name of the file system type (FS type), the number used by fsck to decide whether to check the file system automatically (fsck pass), whether the file system should be mounted automatically by mountall (mount at boot), and the file system mount options (mount options). (See respective mount file system man page below in SEE ALSO for mount options.) A - is used to indicate no entry in a field. This may be used when a field does not apply to the resource being mounted.
The getvfsent(3C) family of routines is used to read and write to /etc/vfstab.
/etc/vfstab can be used to specify swap areas. An entry so specified, (which can be a file or a device), will automatically be added as a swap area by the /sbin/swapadd script when the system boots. To specify a swap area, the device-to-mount field contains the name of the swap file or device, the FS-type is swap, mount-at-boot is no and all other fields have no entry.
iSCSI LUN can only be mounted after the iSCSI initiator SMF service, svc:/network/iscsi/initiator, is started. Set the mount at boot entries for iSCSI LUN in /etc/vfstab to iscsi instead of yes. This enables the iSCSI initiator SMF service to attempt to mount iSCSI LUN later.
The following are vfstab entries for various file system types supported in the Solaris operating environment.
The following entry invokes NFS to automatically mount the directory /usr/local of the server example1 on the client's /usr/local directory with read-only permission:
example1:/usr/local - /usr/local nfs - yes ro |
The following example assumes a small departmental mail setup, in which clients mount /var/mail from a server mailsvr. The following entry would be listed in each client's vfstab:
mailsvr:/var/mail - /var/mail nfs - yes intr,bg |
The following is an example for a UFS file system in which logging is enabled:
/dev/dsk/c2t10d0s0 /dev/rdsk/c2t10d0s0 /export/local ufs 3 yes logging |
See mount_nfs(1M) for a description of NFS mount options and mount_ufs(1M) for a description of UFS options.
The following example mounts a pcfs file system on a fixed hard disk on an x86 machine:
/dev/dsk/c1t2d0p0:c - /win98 pcfs - yes - |
The example below mounts a Jaz drive on a SPARC machine. Normally, the volume management daemon (see vold(1M)) handles mounting of removable media, obviating a vfstab entry. If you choose to specify a device that supports removable media in vfstab, be sure to set the mount-at-boot field to no, as below. Such an entry presumes you are not running vold.
/dev/dsk/c1t2d0s2:c - /jaz pcfs - no - |
For removable media on a SPARC machine, the convention for the slice portion of the disk identifier is to specify s2, which stands for the entire medium.
For pcfs file systems on x86 machines, note that the disk identifier uses a p (p0) and a logical drive (c, in the /win98 example above) for a pcfs logical drive. See mount_pcfs(1M) for syntax for pcfs logical drives and for pcfs-specific mount options.
Below is an example for a CacheFS file system. Because of the length of this entry and the fact that vfstab entries cannot be continued to a second line, the vfstab fields are presented here in a vertical format. In re-creating such an entry in your own vfstab, you would enter values as you would for any vfstab entry, on a single line.
device to mount: svr1:/export/abc device to fsck: /usr/abc mount point: /opt/cache FS type: cachefs fsck pass: 7 mount at boot: yes mount options: local-access,bg,nosuid,demandconst,backfstype=nfs,cachedir=/opt/cache |
See mount_cachefs(1M) for CacheFS-specific mount options.
The following is an example of mounting a loopback (lofs) file system:
/export/test - /opt/test lofs - yes - |
See lofs(7FS) for an overview of the loopback file system.
fsck(1M), mount(1M), mount_cachefs(1M), mount_hsfs(1M), mount_nfs(1M), mount_tmpfs(1M), mount_ufs(1M), swap(1M), getvfsent(3C)
