Name | Description | Files | Attributes | See Also | Diagnostics | Notes
The usb_ah STREAMS module enables the USB input control device which is a member of the Human Interface Device (HID) class and provides support for volume change and mute button. The usb_ah module is pushed on top of a HID class driver instance (see hid(7D)) and below an Audio Control class driver instance (see usb_ac(7D)). It translates the HID specific events to the events that are supported by the Solaris audio mixer framework.
32-bit ELF kernel STREAMS module. (x86 platform only.)
SPARC 64-bit ELF kernel STREAMS module
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
PCI-based systems |
Availability |
SUNWusb |
Interface Stability |
Evolving |
mixerctl(1), hid(7D), usba(7D), usb_ac(7D), usb_as(7D), usb_mid(7D), audio(7I), mixer(7I)
STREAMS Programming Guide
System Administration Guide: Basic Administration
Universal Serial Bus Specification 1.0 and 1.1
Device Class Definition for Human Interface Devices (HID) 1.1
None
If USB audio drivers are not loaded, buttons will not be active.
