Name | Synopsis | Interface Level | Parameters | Description | Structure Members | Return Values | Context | See Also
#include <sys/pccard.h> int32_t csx_Parse_CISTPL_JEDEC_C(client_handle_t ch, tuple_t *tu, cistpl_jedec_t *cj);
int32_t csx_Parse_CISTPL_JEDEC_A(client_handle_t ch, tuple_t *tu, cistpl_jedec_t *cj);
Solaris DDI Specific (Solaris DDI)
Client handle returned from csx_RegisterClient(9F).
Pointer to a tuple_t structure (see tuple(9S)) returned by a call to csx_GetFirstTuple(9F) or csx_GetNextTuple(9F).
Pointer to a cistpl_jedec_t structure which contains the parsed CISTPL_JEDEC_C or CISTPL_JEDEC_A tuple information upon return from these functions, respectively.
csx_Parse_CISTPL_JEDEC_C() and csx_Parse_CISTPL_JEDEC_A() parse the JEDEC Identifier tuples, CISTPL_JEDEC_C and CISTPL_JEDEC_A, respectively, into a form usable by PC Card drivers.
The CISTPL_JEDEC_C and CISTPL_JEDEC_A tuples are optional tuples provided for cards containing programmable devices. They describe information for Common Memory or Attribute Memory space, respectively.
uint32_t nid; /* # of JEDEC identifiers present */ jedec_ident_t jid[CISTPL_JEDEC_MAX_IDENTIFIERS];
The structure members of jedec_ident_t are:
uint32_t id; /* manufacturer id */ uint32_t info; /* manufacturer specific info */
Successful operation.
Client handle is invalid.
Parser does not know how to parse tuple.
No PC Card in socket.
No Card Information Structure (CIS) on PC Card.
No PCMCIA hardware installed.
These functions may be called from user or kernel context.
csx_GetFirstTuple(9F), csx_GetTupleData(9F), csx_Parse_CISTPL_DEVICE(9F), csx_RegisterClient(9F), csx_ValidateCIS(9F), tuple(9S)
PC Card 95 Standard, PCMCIA/JEIDA
