Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | See Also
#include <sys/ddi.h> #include <sys/sunddi.h> int ddi_dma_alloc_handle(dev_info_t *dip, ddi_dma_attr_t *attr, int (*callback) (caddr_t), caddr_t arg, ddi_dma_handle_t *handlep);
Solaris DDI specific (Solaris DDI).
Pointer to the device's dev_info structure.
Pointer to a DMA attribute structure for this device (see ddi_dma_attr(9S)).
The address of a function to call back later if resources aren't available now. The following special function addresses may also be used.
Wait until resources are available.
Do not wait until resources are available and do not schedule a callback.
Argument to be passed to a callback function, if such a function is specified.
Pointer to the DMA handle to be initialized.
ddi_dma_alloc_handle() allocates a new DMA handle. A DMA handle is an opaque object used as a reference to subsequently allocated DMA resources. ddi_dma_alloc_handle() accepts as parameters the device information referred to by dip and the device's DMA attributes described by a ddi_dma_attr(9S) structure. A successful call to ddi_dma_alloc_handle() fills in the value pointed to by handlep. A DMA handle must only be used by the device for which it was allocated and is only valid for one I/O transaction at a time.
The callback function, callback, indicates how a caller wants to handle the possibility of resources not being available. If callback is set to DDI_DMA_DONTWAIT, then the caller does not care if the allocation fails, and can handle an allocation failure appropriately. If callback is set to DDI_DMA_SLEEP, then the caller wishes to have the allocation routines wait for resources to become available. If any other value is set, and a DMA resource allocation fails, this value is assumed to be a function to call at a later time when resources may become available. When the specified function is called, it is passed arg as an argument. The specified callback function must return either DDI_DMA_CALLBACK_RUNOUT or DDI_DMA_CALLBACK_DONE. DDI_DMA_CALLBACK_RUNOUT indicates that the callback routine attempted to allocate DMA resources but failed to do so, in which case the callback function is put back on a list to be called again later. DDI_DMA_CALLBACK_DONE indicates either success at allocating DMA resources or the driver no longer wishes to retry.
The callback function is called in interrupt context. Therefore, only system functions that are accessible from interrupt context is available. The callback function must take whatever steps necessary to protect its critical resources, data structures, queues, and so forth.
When a DMA handle is no longer needed, ddi_dma_free_handle(9F) must be called to free the handle.
ddi_dma_alloc_handle() returns:
Successfully allocated a new DMA handle.
The attributes specified in the ddi_dma_attr(9S) structure make it impossible for the system to allocate potential DMA resources.
No resources are available.
ddi_dma_alloc_handle() can be called from user, kernel, or interrupt context, except when callback is set to DDI_DMA_SLEEP, in which case it can be called from user or kernel context only.
ddi_dma_addr_bind_handle(9F), ddi_dma_buf_bind_handle(9F), ddi_dma_burstsizes(9F), ddi_dma_free_handle(9F), ddi_dma_unbind_handle(9F), ddi_dma_attr(9S)
