Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | Attributes | See Also
#include <sys/conf.h>
#include <sys/ddi.h>
#include <sys/sunddi.h>
int ddi_dma_htoc(ddi_dma_handle_t handle, off_t off,
     ddi_dma_cookie_t *cookiep);
This interface is obsolete. ddi_dma_addr_bind_handle(9F) or ddi_dma_buf_bind_handle(9F) should be used instead.
The handle filled in by a call to ddi_dma_setup(9F).
An offset into the object that handle maps.
A pointer to a ddi_dma_cookie(9S) structure.
The ddi_dma_htoc() function takes a DMA handle (established by ddi_dma_setup(9F)), and fills in the cookie pointed to by cookiep with the appropriate address, length, and bus type to be used to program the DMA engine.
The ddi_dma_htoc() function returns:
Successfully filled in the cookie pointed to by cookiep.
Failed to successfully fill in the cookie.
The ddi_dma_htoc() function can be called from user, interrupt, or kernel context.
See attributes(5) for a description of the following attributes:
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Stability Level  |
 Obsolete  |
attributes(5), ddi_dma_addr_bind_handle(9F), ddi_dma_addr_setup(9F), ddi_dma_buf_bind_handle(9F), ddi_dma_buf_setup(9F), ddi_dma_setup(9F), ddi_dma_sync(9F), ddi_dma_cookie(9S)
