Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | Attributes | See Also | Notes
#include <sys/types.h> #include <sys/conf.h> #include <sys/ddi.h> #include <sys/sunddi.h> int ddi_intr_get_nintrs(dev_info_t *dip, int type, int *nintrsp);
int ddi_intr_get_navail(dev_info_t *dip, int type, int *navailp);
Solaris DDI specific (Solaris DDI).
ddi_intr_get_nintrs()
Pointer to dev_info structure
Interrupt type
Pointer to number of interrupts of the given type that are supported by the system
ddi_intr_get_navail()
Interrupt type
Pointer to number of interrupts of the given type that are currently available from the system
The ddi_intr_get_nintrs() function returns the number of interrupts of the given type supported by a particular hardware device. On a successful return, the number of supported interrupts is returned as an integer pointed to by the nintrsp argument.
If the hardware device is not found to support any interrupts of the given type, the DDI_INTR_NOTFOUND failure is returned rather than a zero in nintrsp.
The ddi_intr_get_navail() function returns the number of interrupts of a given type that is available to a particular hardware device. On a successful return, the number of available interrupts is returned as an integer pointed to by navailp.
The hardware device may support more than one interrupt and can request that all interrupts be allocated. The host software can then use policy-based decisions to determine how many interrupts are made available to the device. Based on the determination, a value is returned that should be used to allocate interrupts with the ddi_int_alloc() function.
If the device participates in resource management, a call to ddi_intr_get_navail() tells the device driver the number of interrupts of the given type that should be used. The host software can then use a policy-based decision to determine the number of interrupts to be allowed to the device. If the number is more than the number of interrupts currently being used, the device driver can ask for more resources. If the number is less than the number of interrupts currently being used, the device driver should prepare to disable and free the extra interrupts. The number of interrupts currently available is always a snapshot in time and can change if the interface is called again.
See ddi_intr_get_supported_types(9F) for a list of valid supported types for a given hardware device. The ddi_intr_get_supported_types() function must be called prior to calling either ddi_intr_get_nintrs() or ddi_intr_get_navail().
The ddi_intr_get_nintrs() and ddi_intr_get_navail() functions return:
On success.
On encountering invalid input parameters.
On not finding any interrupts for the given interrupt type.
On any implementation specific failure.
The ddi_intr_get_nintrs() and ddi_intr_get_navail() functions can be called from either user or kernel non-interrupt context.
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Interface Stability  |
 Evolving  |
The ddi_intr_get_nintrs() and ddi_intr_get_navail() functions can be called at any time, even if the driver has added an interrupt handler for a given interrupt specification.
Consumers of these interfaces should verify that the return value is not equal to DDI_SUCCESS. Incomplete checking for failure codes could result in inconsistent behavior among platforms.
