Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | Attributes | See Also | Notes
#include <sys/types.h> #include <sys/conf.h> #include <sys/ddi.h> #include <sys/sunddi.h> int ddi_intr_set_mask(ddi_intr_handle_t h);
int ddi_intr_clr_mask(ddi_intr_handle_t h);
Solaris DDI specific (Solaris DDI).
The ddi_intr_set_mask() function masks the given interrupt pointed to by the device's interrupt handle h if the device or host bridge supports the masking operation. The ddi_intr_get_cap() function returns the RO flag DDI_INTR_FLAG_MASKABLE if the device or host bridge supports interrupt mask bits for the given interrupt type. In flight interrupts can still be taken and delivered to the driver.
The ddi_intr_clr_mask() function unmasks the given interrupt pointed by the device's interrupt handle h if the device or host bridge supports the masking operation.
The ddi_intr_set_mask() and ddi_intr_clr_mask() functions should be called only if an interrupt is enabled. Otherwise the framework will return DDI_EINVAL to such calls.
The mask cannot be cleared directly if the OS implementation has also temporarily masked the interrupt. A call to ddi_intr_clr_mask() must be preceded by a call to ddi_intr_set_mask(). It is not necessary to call ddi_intr_clr_mask() when adding and enabling the interrupt.
The ddi_intr_set_mask() and ddi_intr_clr_mask() functions return:
On success.
On encountering invalid input parameters or when an interrupt is not enabled.
On any implementation specific failure.
On device not supporting operation.
The ddi_intr_set_mask() and ddi_intr_clr_mask() functions can be called from any context.
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Interface Stability  |
 Evolving  |
attributes(5), ddi_intr_block_disable(9F), ddi_intr_block_enable(9F), ddi_intr_disable(9F), ddi_intr_enable(9F), ddi_intr_get_pending(9F)
Consumers of these interfaces should verify that the return value is not equal to DDI_SUCCESS. Incomplete checking for failure codes could result in inconsistent behavior among platforms.
