Name | Synopsis | Interface Level | Parameters | Description | Context | See Also | Notes
#include <sys/ddi.h> #include <sys/sunddi.h> uint8_t ddi_mem_get8(ddi_acc_handle_t handle, uint8_t *dev_addr);
uint16_t ddi_mem_get16(ddi_acc_handle_t handle, uint16_t * dev_addr);
uint32_t ddi_mem_get32(ddi_acc_handle_t handle, uint32_t *dev_addr);
uint64_t ddi_mem_get64(ddi_acc_handle_t handle, uint64_t *dev_addr);
Solaris DDI specific (Solaris DDI).
The data access handle returned from setup calls, such as ddi_regs_map_setup(9F).
Base device address.
These routines generate a read of various sizes from memory space or allocated DMA memory. The ddi_mem_get8(), ddi_mem_get16(), ddi_mem_get32(), and ddi_mem_get64() functions read 8 bits, 16 bits, 32 bits and 64 bits of data, respectively, from the device address, dev_addr, in memory space.
Each individual datum will automatically be translated to maintain a consistent view between the host and the device based on the encoded information in the data access handle. The translation may involve byte-swapping if the host and the device have incompatible endian characteristics.
These functions can be called from user, kernel, or interrupt context.
ddi_mem_put8(9F), ddi_mem_rep_get8(9F), ddi_mem_rep_put8(9F), ddi_regs_map_setup(9F), ddi_device_acc_attr(9S)
The functions described in this manual page previously used symbolic names which specified their data access size; the function names have been changed so they now specify a fixed-width data size. See the following table for the new name equivalents:
 Previous Name  |
 New Name  |
 ddi_mem_getb  |
 ddi_mem_get8  |
 ddi_mem_getw  |
 ddi_mem_get16  |
 ddi_mem_getl  |
 ddi_mem_get32  |
 ddi_mem_getll  |
 ddi_mem_get64  |
