Name | Synopsis | Interface Level | Description | Return Values | Context | Examples | See Also
#include <sys/ddi.h> #include <sys/sunddi.h> uint_t ddi_mmap_get_model(void);
Solaris DDI specific (Solaris DDI).
ddi_mmap_get_model() returns the C Language Type Model which the current thread expects. ddi_mmap_get_model() is used in combination with ddi_model_convert_from(9F) in the mmap(9E) driver entry point to determine whether there is a data model mismatch between the current thread and the device driver. The device driver might have to adjust the shape of data structures before exporting them to a user thread which supports a different data model.
Current thread expects 32-bit (ILP32) semantics.
Current thread expects 64-bit (LP64) semantics.
The ddi_mmap_get_model() function was not called from the mmap(9E) entry point.
The ddi_mmap_get_model() function can only be called from the mmap(9E) driver entry point.
The following is an example of the mmap(9E) entry point and how to support 32-bit and 64-bit applications with the same device driver.
struct data32 {
int len;
caddr32_t addr;
struct data {
int len;
caddr_t addr;
xxmmap(dev_t dev, off_t off, int prot) {
struct data dtc; /* a local copy for clash resolution */
struct data *dp = (struct data *)shared_area;
switch (ddi_model_convert_from(ddi_mmap_get_model())) {
case DDI_MODEL_ILP32:
struct data32 *da32p;
da32p = (struct data32 *)shared_area;
dp = &dtc;
dp->len = da32p->len;
dp->address = da32->address;
break;
case DDI_MODEL_NONE:
break;
/* continues along using dp */
