Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | Examples | See Also | Notes
#include <sys/ksynch.h>
void mutex_init(kmutex_t *mp, char *name, kmutex_type_t type,
     void *arg);
void mutex_destroy(kmutex_t *mp);
void mutex_enter(kmutex_t *mp);
void mutex_exit(kmutex_t *mp);
int mutex_owned(kmutex_t *mp);
int mutex_tryenter(kmutex_t *mp);
Solaris DDI specific (Solaris DDI).
Pointer to a kernel mutex lock (kmutex_t).
Descriptive string. This is obsolete and should be NULL. (Non-NULL strings are legal, but they are a waste of kernel memory.)
Type of mutex lock.
Type-specific argument for initialization routine.
A mutex enforces a policy of mutual exclusion. Only one thread at a time may hold a particular mutex. Threads trying to lock a held mutex will block until the mutex is unlocked.
Mutexes are strictly bracketing and may not be recursively locked, meaning that mutexes should be exited in the opposite order they were entered, and cannot be reentered before exiting.
mutex_init() initializes a mutex. It is an error to initialize a mutex more than once. The type argument should be set to MUTEX_DRIVER.
arg provides type-specific information for a given variant type of mutex. When mutex_init() is called for driver mutexes, if the mutex is used by the interrupt handler, the arg should be the interrupt priority returned from ddi_intr_get_pri(9F) or ddi_intr_get_softint_pri(9F). Note that arg should be the value of the interrupt priority cast by calling the DDI_INTR_PRI macro. If the mutex is never used inside an interrupt handler, the argument should be NULL.
mutex_enter() is used to acquire a mutex. If the mutex is already held, then the caller blocks. After returning, the calling thread is the owner of the mutex. If the mutex is already held by the calling thread, a panic ensues.
mutex_owned() should only be used in ASSERT() and may be enforced by not being defined unless the preprocessor symbol DEBUG is defined. Its return value is non-zero if the current thread (or, if that cannot be determined, at least some thread) holds the mutex pointed to by mp.
mutex_tryenter() is very similar to mutex_enter() except that it doesn't block when the mutex is already held. mutex_tryenter() returns non-zero when it acquired the mutex and 0 when the mutex is already held.
mutex_exit() releases a mutex and will unblock another thread if any are blocked on the mutex.
mutex_destroy() releases any resources that might have been allocated by mutex_init(). mutex_destroy() must be called before freeing the memory containing the mutex, and should be called with the mutex unheld (not owned by any thread). The caller must be sure that no other thread attempts to use the mutex.
mutex_tryenter() returns non-zero on success and zero on failure.
mutex_owned() returns non-zero if the calling thread currently holds the mutex pointed to by mp, or when that cannot be determined, if any thread holds the mutex. mutex_owned() returns zero.
These functions can be called from user, kernel, or high-level interrupt context, except for mutex_init() and mutex_destroy(), which can be called from user or kernel context only.
A driver might do this to initialize a mutex that is part of its unit structure and used in its interrupt routine:
ddi_intr_get_pri(hdlp, &pri); mutex_init(&un->un_lock, NULL, MUTEX_DRIVER, DDI_INTR_PRI(pri)); ddi_intr_add_handler(hdlp, xxintr, (caddr_t)un, NULL);
A routine that expects to be called with a certain lock held might have the following ASSERT:
xxstart(struct xxunit *un)
	      ASSERT(mutex_owned(&un->un_lock));
lockstat(1M), Intro(9F), condvar(9F), ddi_intr_alloc(9F), ddi_intr_add_handler(9F), ddi_intr_get_pri(9F), ddi_intr_get_softint_pri(9F), rwlock(9F), semaphore(9F)
Compiling with _LOCKTEST or _MPSTATS defined has no effect. To gather lock statistics, see lockstat(1M).
The address of a kmutex_t lock must be aligned on an 8-byte boundary for 64-bit kernels, or a 4-byte boundary for 32-bit kernels. Violation of this requirement will result in undefined behavior, including, but not limited to, failure of mutual exclusion or a system panic.
To write scalable, responsive drivers that do not hang, panic or deadlock the system, follow these guidelines:
 Never return from a driver entry point with a mutex held.  |
 Never hold a mutex when calling a service that may block, for example kmem_alloc(9F) with KM_SLEEP or delay(9F).  |
 Always acquire mutexes in a consistent order. If a critical section acquires mutex A followed by B, and elsewhere in the driver mutex B is acquired before A, the driver can deadlock with one thread holding A and waiting for B and another thread holding B while waiting for A.  |
 Always use a mutex to enforce exclusive access to data, not instruction paths.  |
 Acquiring a lock in user context that is also acquired in interrupt context means that, as long as that lock is held, the driver instance holding the lock is subject to all the rules and limitations of interrupt context.  |
 In most cases, a mutex can and should be acquired and released within the same function.  |
 Liberal use of debugging aids like ASSERT(mutex_owned(&mutex)) can help find callers of a function which should be holding a mutex but are not. This means you need to test your driver compiled with DEBUG.  |
 Do not use a mutex to set driver state. However, you should use a mutex to protect driver state data.  |
 Use per-instance and automatic data where possible to reduce the amount of shared data. Per-instance data can be protected by a per-instance lock to improve scalability and reduce contention with multiple hardware instances.  |
 Avoid global data and global mutexes whenever possible.  |
