Name | Synopsis | Interface Level | Parameters | Description | Context | Return Values | Examples | Attributes | See Also | Notes
#include <sys/types.h> #include <sys/errno.h> #include <sys/sunddi.h> int uconv_u16tou32(const uint16_t *utf16str, size_t *utf16len, uint32_t *utf32str, size_t *utf32len, int flag);
int uconv_u16tou8(const uint16_t *utf16str, size_t *utf16len, uchar_t *utf8str, size_t *utf8len, int flag);
int uconv_u32tou16(const uint32_t *utf32str, size_t *utf32len, uint16_t *utf16str, size_t *utf16len, int flag);
int uconv_u32tou8(const uint32_t *utf32str, size_t *utf32len, uchar_t *utf8str, size_t *utf8len, int flag);
int uconv_u8tou16(const uchar_t *utf8str, size_t *utf8len, uint16_t *utf16str, size_t *utf16len, int flag);
int uconv_u8tou32(const uchar_t *utf8str, size_t *utf8len, uint32_t *utf32str, size_t *utf32len, int flag);
Solaris DDI specific (Solaris DDI).
A pointer to a UTF-16 character string.
As an input parameter, the number of 16-bit unsigned integers in utf16str as UTF-16 characters to be converted or saved.
As an output parameter, the number of 16-bit unsigned integers in utf16str consumed or saved during conversion.
A pointer to a UTF-32 character string.
As an input parameter, the number of 32-bit unsigned integers in utf32str as UTF-32 characters to be converted or saved.
As an output parameter, the number of 32-bit unsigned integers in utf32str consumed or saved during conversion.
A pointer to a UTF-8 character string.
As an input parameter, the number of bytes in utf8str as UTF-8 characters to be converted or saved.
As an output parameter, the number of bytes in utf8str consumed or saved during conversion.
The possible conversion options that are constructed by a bitwise-inclusive-OR of the following values:
The input parameter is in big endian byte ordering.
The output parameter should be in big endian byte ordering.
The input parameter is in the default byte ordering of the current system.
The output parameter should be in the default byte ordering of the current system.
The input parameter is in little endian byte ordering.
The output parameter should be in little endian byte ordering.
The null or U+0000 character should not stop the conversion.
If the Byte Order Mark (BOM, U+FEFF) character exists as the first character of the input parameter, interpret it as the BOM character.
Start the output parameter with Byte Order Mark (BOM, U+FEFF) character to indicate the byte ordering if the output parameter is in UTF-16 or UTF-32.
The uconv_u16tou32() function reads the given utf16str in UTF-16 until U+0000 (zero) in utf16str is encountered as a character or until the number of 16-bit unsigned integers specified in utf16len is read. The UTF-16 characters that are read are converted into UTF-32 and the result is saved at utf32str. After the successful conversion, utf32len contains the number of 32-bit unsigned integers saved at utf32str as UTF-32 characters.
The uconv_u16tou8() function reads the given utf16str in UTF-16 until U+0000 (zero) in utf16str is encountered as a character or until the number of 16-bit unsigned integers specified in utf16len is read. The UTF-16 characters that are read are converted into UTF-8 and the result is saved at utf8str. After the successful conversion, utf8len contains the number of bytes saved at utf8str as UTF-8 characters.
The uconv_u32tou16() function reads the given utf32str in UTF-32 until U+0000 (zero) in utf32str is encountered as a character or until the number of 32-bit unsigned integers specified in utf32len is read. The UTF-32 characters that are read are converted into UTF-16 and the result is saved at utf16str. After the successful conversion, utf16len contains the number of 16-bit unsigned integers saved at utf16str as UTF-16 characters.
The uconv_u32tou8() function reads the given utf32str in UTF-32 until U+0000 (zero) in utf32str is encountered as a character or until the number of 32-bit unsigned integers specified in utf32len is read. The UTF-32 characters that are read are converted into UTF-8 and the result is saved at utf8str. After the successful conversion, utf8len contains the number of bytes saved at utf8str as UTF-8 characters.
The uconv_u8tou16() function reads the given utf8str in UTF-8 until the null ('\0') byte in utf8str is encountered or until the number of bytes specified in utf8len is read. The UTF-8 characters that are read are converted into UTF-16 and the result is saved at utf16str. After the successful conversion, utf16len contains the number of 16-bit unsigned integers saved at utf16str as UTF-16 characters.
The uconv_u8tou32() function reads the given utf8str in UTF-8 until the null ('\0') byte in utf8str is encountered or until the number of bytes specified in utf8len is read. The UTF-8 characters that are read are converted into UTF-32 and the result is saved at utf32str. After the successful conversion, utf32len contains the number of 32-bit unsigned integers saved at utf32str as UTF-32 characters.
During the conversion, the input and the output parameters are treated with byte orderings specified in the flag parameter. When not specified, the default byte ordering of the system is used. The byte ordering flag value that is specified for UTF-8 is ignored.
When UCONV_IN_ACCEPT_BOM is specified as the flag and the first character of the string pointed to by the input parameter is the BOM character, the value of the BOM character dictates the byte ordering of the subsequent characters in the string pointed to by the input parameter, regardless of the supplied input parameter byte ordering option flag values. If the UCONV_IN_ACCEPT_BOM is not specified, the BOM as the first character is treated as a regular Unicode character: Zero Width No Break Space (ZWNBSP) character.
When UCONV_IGNORE_NULL is specified, regardless of whether the input parameter contains U+0000 or null byte, the conversion continues until the specified number of input parameter elements at utf16len, utf32len, or utf8len are entirely consumed during the conversion.
As output parameters, utf16len, utf32len, and utf8len are not changed if conversion fails for any reason.
The uconv_u16tou32(), uconv_u16tou8(), uconv_u32tou16(), uconv_u32tou8(), uconv_u8tou16(), and uconv_u8tou32() functions can be called from user or interrupt context.
Upon successful conversion, the functions return 0. Upon failure, the functions return one of the following errno values:
The conversion detected an illegal or out of bound character value in the input parameter.
The conversion cannot finish because the size specified in the output parameter is too small.
The conversion stops due to an incomplete character at the end of the input string.
Conflicting byte-ordering option flag values are detected.
#include <sys/types.h> #include <sys/errno.h> #include <sys/sunddi.h> . . . uint16_t u16s[MAXNAMELEN + 1]; uchar_t u8s[MAXNAMELEN + 1]; size_t u16len, u8len; int ret; . . . u16len = u8len = MAXNAMELEN; ret = uconv_u16tou8(u16s, &u16len, u8s, &u8len, UCONV_IN_LITTLE_ENDIAN); if (ret != 0) { /* Conversion error occurred. */ return (ret); } . . .
#include <sys/types.h> #include <sys/errno.h> #include <sys/sunddi.h> . . . /* * An UTF-32 character can be mapped to an UTF-16 character with * two 16-bit integer entities as a "surrogate pair." */ uint32_t u32s[101]; uint16_t u16s[101]; int ret; size_t u32len, u16len; . . . u32len = u16len = 100; ret = uconv_u32tou16(u32s, &u32len, u16s, &u16len, UCONV_IN_BIG_ENDIAN | UCONV_OUT_LITTLE_ENDIAN); if (ret == 0) { return (0); } else if (ret == E2BIG) { /* Use bigger output parameter and try just one more time. */ uint16_t u16s2[201]; u16len = 200; ret = uconv_u32tou16(u32s, &u32len, u16s2, &u16len, UCONV_IN_BIG_ENDIAN | UCONV_OUT_LITTLE_ENDIAN); if (ret == 0) return (0); } /* Otherwise, return -1 to indicate an error condition. */ return (-1);
Convert a UTF-8 string into UTF-16 in little-endian byte ordering with a Byte Order Mark (BOM) character at the beginning of the output parameter.
#include <sys/types.h> #include <sys/errno.h> #include <sys/sunddi.h> . . . uchar_t u8s[MAXNAMELEN + 1]; uint16_t u16s[MAXNAMELEN + 1]; size_t u8len, u16len; int ret; . . . u8len = u16len = MAXNAMELEN; ret = uconv_u8tou16(u8s, &u8len, u16s, &u16len, UCONV_IN_LITTLE_ENDIAN | UCONV_EMIT_BOM); if (ret != 0) { /* Conversion error occurred. */ return (ret); } . . .
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Interface Stability |
Committed |
Each UTF-16 or UTF-32 character maps to an UTF-8 character that might need one to maximum of four bytes.
One UTF-32 or UTF-8 character can yield two 16-bit unsigned integers as a UTF-16 character, which is a surrogate pair if the Unicode scalar value is bigger than U+FFFF.
Ill-formed UTF-16 surrogate pairs are seen as illegal characters during the conversion.
