Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | See Also | Warnings
#include <sys/types.h>
#include <sys/uio.h>
int uiomove(caddr_t address, size_t nbytes, enum uio_rw rwflag,
     uio_t *uio_p);
Architecture independent level 1 (DDI/DKI).
Source/destination kernel address of the copy.
Number of bytes to copy.
Flag indicating read or write operation. Possible values are UIO_READ and UIO_WRITE.
Pointer to the uio structure for the copy.
The uiomove() function copies nbytes of data to or from the space defined by the uio structure (described in uio(9S)) and the driver.
The uio_segflg member of the uio(9S) structure determines the type of space to or from which the transfer is being made. If it is set to UIO_SYSSPACE, the data transfer is between addresses in the kernel. If it is set to UIO_USERSPACE, the transfer is between a user program and kernel space.
rwflag indicates the direction of the transfer. If UIO_READ is set, the data will be transferred from address to the buffer(s) described by uio_p. If UIO_WRITE is set, the data will be transferred from the buffer(s) described by uio_p to address.
In addition to moving the data, uiomove() adds the number of bytes moved to the iov_base member of the iovec(9S) structure, decreases the iov_len member, increases the uio_offset member of the uio(9S) structure, and decreases the uio_resid member.
This function automatically handles page faults. nbytes does not have to be word-aligned.
The uiomove() function returns 0 upon success or EFAULT on failure.
User context only, if uio_segflg is set to UIO_USERSPACE. User, interrupt, or kernel context, if uio_segflg is set to UIO_SYSSPACE.
If uio_segflg is set to UIO_SYSSPACE and address is selected from user space, the system may panic.
