Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | See Also
#include <sys/stream.h> void unbufcall(bufcall_id_t id);
Architecture independent level 1 (DDI/DKI).
Identifier returned from bufcall(9F) or esbbcall(9F).
The unbufcall function cancels a pending bufcall() or esbbcall() request. The argument id is a non-zero identifier for the request to be cancelled. id is returned from the bufcall() or esbbcall() function used to issue the request. unbufcall() will not return until the pending callback is cancelled or has run. Because of this, locks acquired by the callback routine should not be held across the call to unbufcall() or deadlock may result.
None.
The unbufcall function can be called from user, interrupt, or kernel context.
