Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | Examples | Attributes | See Also
#include <sys/usb/usba.h> int usb_create_pm_components(dev_info_t *dip, uint_t *pwrstates);
Solaris DDI specific (Solaris DDI)
Pointer to the device's dev_info structure.
Address into which a mask which lists power states capable by device is returned. This is a bitmask containing zero or more of the following values:
Corresponds to USB_DEV_OS_PWR_3 or full power.
Corresponds to USB_DEV_OS_PWR_2.
Corresponds to USB_DEV_OS_PWR_1.
Corresponds to USB_DEV_OS_PWR_0 or no power.
The usb_create_pm_components() function creates pm component properties that assume the standard USB D0-D3 powerlevels (USB_DEV_PWR_D0 - USB_DEV_PWR_D3). See the device's relevant USB descriptor to determine the device's power management capabilities and account for bus-powered devices. The usb_create_pm_components() function also updates the pm-components property in the device's dev_info structure.
Note that these USB power levels are inverse of OS power levels. For example, USB_DEV_OS_PWR_0 and USB_DEV_PWR_D3 are equivalent levels corresponding to powered-down.
Power management facilities in device are recognized by system.
An error occurred.
May be called from user or kernel context.
uint_t *pwrstates;
/* Hook into device's power management. Enable remote wakeup. */
if (usb_create_pm_components(dip, pwrstates) == USB_SUCCESS) {
usb_handle_remote_wakeup(dip,USB_REMOTE_WAKEUP_ENABLE);
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Architecture |
PCI-based systems |
Interface stability |
Evolving |
Availability |
SUNWusb |
attributes(5), usb_clr_feature(9F), usb_register_hotplug_cbs(9F), usb_get_cfg(9F), usb_get_dev_data(9F), usb_handle_remote_wakeup(9F), pm_idle_component(9F), pm_busy_component(9F), pm_raise_power(9F), pm_lower_power(9F), usb_cfg_descr(9S)
