Name | Synopsis | Interface Level | Parameters | Description | Return Values | Context | Examples | Attributes | See Also
#include <sys/usb/usba.h>
int usb_pipe_open(dev_info_t *dip, usb_ep_descr_t *endpoint, usb_pipe_policy_t *pipe_policy,
     usb_flags_t flags, usb_pipe_handle_t *pipe_handle);
Solaris DDI specific (Solaris DDI)
Pointer to the device's dev_info structure.
Pointer to endpoint descriptor.
Pointer to pipe_policy. pipe_policy provides hints on pipe usage.
USB_FLAGS_SLEEP is only flag that is recognized. Wait for memory resources if not immediately available.
Address to where new pipe handle is returned. (The handle is opaque.)
A pipe is a logical connection to an endpoint on a USB device. The usb_pipe_open() function creates such a logical connection and returns an initialized handle which refers to that connection.
The USB 2.0 specification defines four endpoint types, each with a corresponding type of pipe. Each of the four types of pipes uses its physical connection resource differently. They are:
Used for bursty, non-periodic, reliable, host-initiated request/response communication, such as for command/status operations. These are guaranteed to get approximately 10% of frame time and will get more if needed and if available, but there is no guarantee on transfer promptness. Bidirectional.
Used for large, reliable, non-time-critical data transfers. These get the bus on a bandwidth-available basis. Unidirectional. Sample uses include printer data.
Used for sending or receiving small amounts of reliable data infrequently but with bounded service periods, as for interrupt handling. Unidirectional.
Used for large, unreliable, time-critical data transfers. Boasts a guaranteed constant data rate as long as there is data, but there are no retries of failed transfers. Interrupt and isochronous data are together guaranteed 90% of frame time as needed. Unidirectional. Sample uses include audio.
The type of endpoint to which a pipe connects (and therefore the pipe type) is defined by the bmAttributes field of that pipe's endpoint descriptor. (See usb_ep_descr(9S)). Opens to interrupt and isochronous pipes can fail if the required bandwidth cannot be guaranteed.
The polling interval for periodic (interrupt or isochronous) pipes, carried by the endpoint argument's bInterval field, must be within range. Valid ranges are:
Full speed: range of 1-255 maps to 1-255 ms.
Low speed: range of 10-255 maps to 10-255 ms.
High speed: range of 1-16 maps to (2**(bInterval-1)) * 125us.
Adequate bandwidth during transfers is guaranteed for all periodic pipes which are opened successfully. Interrupt and isochronous pipes have guaranteed latency times, so bandwidth for them is allocated when they are opened. (Please refer to Sections 5.7 and 5.8 of the USB 2.0 specification which address isochronous and interrupt transfers.) Opens of interrupt and isochronous pipes fail if inadequate bandwidth is available to support their guaranteed latency time. Because periodic pipe bandwidth is allocated on pipe open, open periodic pipes only when needed.
The bandwidth required by a device varies based on polling interval, the maximum packet size (wMaxPacketSize) and the device speed. Unallocated bandwidth remaining for new devices depends on the bandwidth already allocated for previously opened periodic pipes.
The pipe_policy parameter provides a hint as to pipe usage and must be specified. It is a usb_pipe_policy_t which contains the following fields:
uchar_t         pp_max_async_reqs:
                   A hint indicating how many
                   asynchronous operations requiring
                   their own kernel thread will be
                   concurrently in progress, the highest
                   number of threads ever needed at one
                   time.  Allow at least one for
                   synchronous callback handling and as
                   many as are needed to accommodate the
                   anticipated parallelism of asynchronous*
                   calls to the following functions:
                           usb_pipe_close(9F)
                           usb_set_cfg(9F)
                           usb_set_alt_if(9F)
                           usb_clr_feature(9F)
                           usb_pipe_reset(9F)
                           usb_pipe_drain_reqs(9F)
                           usb_pipe_stop_intr_polling(9F)
                           usb_pipe_stop_isoc_polling(9F)
                  Setting to too small a value can
                  deadlock the pipe.
                  * Asynchronous calls are calls made
                    without the USB_FLAGS_SLEEP flag being
                    passed.  Note that a large number of
                    callbacks becomes an issue mainly when
                    blocking functions are called from
                    callback handlers.
The control pipe to the default endpoints (endpoints for both directions with addr 0, sometimes called the default control pipe or default pipe) comes pre-opened by the hub. A client driver receives the default control pipe handle through usb_get_dev_data(9F). A client driver cannot open the default control pipe manually. Note that the same control pipe may be shared among several drivers when a device has multiple interfaces and each interface is operated by its own driver.
All explicit pipe opens are exclusive; attempts to open an opened pipe fail.
On success, the pipe_handle argument points to an opaque handle of the opened pipe. On failure, it is set to NULL.
Open succeeded.
Insufficient resources were available.
Insufficient bandwidth available. (isochronous and interrupt pipes).
Called from interrupt handler with USB_FLAGS_SLEEP set.
dip and/or pipe_handle is NULL. Pipe_policy is NULL.
Endpoint is NULL, signifying the default control pipe. A client driver cannot open the default control pipe.
Isochronous or interrupt endpoint with maximum packet size of zero is not supported.
Host controller is in an error state.
Pipe is already open. Host controller not in an operational state. Polling interval (ep_descr bInterval field) is out of range (intr or isoc pipes).
May be called from user or kernel context regardless of arguments. May also be called from interrupt context if the USB_FLAGS_SLEEP option is not set.
    usb_ep_data_t *ep_data;
    usb_pipe_policy_t policy;
    usb_pipe_handle_t pipe;
    usb_client_dev_data_t *reg_data;
    uint8_t interface = 1;
    uint8_t alternate = 1;
    uint8_t first_ep_number = 0;
    /* Initialize pipe policy. */
    bzero(policy, sizeof(usb_pipe_policy_t));
    policy.pp_max_async_requests = 2;
    /* Get tree of descriptors for device. */
    if (usb_get_dev_data(
        dip, USBDRV_VERSION, ®_data, USB_FLAGS_ALL_DESCR, 0) !=
        USB_SUCCESS) {
    /* Get first interrupt-IN endpoint. */
    ep_data = usb_lookup_ep_data(dip, reg_data, interface, alternate,
        first_ep_number, USB_EP_ATTR_INTR, USB_EP_DIR_IN);
    if (ep_data == NULL) {
    /* Open the pipe.  Get handle to pipe back in 5th argument. */
    if (usb_pipe_open(dip, &ep_data.ep_descr
        &policy, USB_FLAGS_SLEEP, &pipe) != USB_SUCCESS) {
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Architecture  |
 PCI-based systems  |
 Interface stability  |
 Evolving  |
 Availability  |
 SUNWusb  |
attributes(5), usb_get_alt_if(9F), usb_get_cfg(9F), usb_get_status(9F), usb_get_dev_data(9F), usb_pipe_bulk_xfer(9F), usb_pipe_ctrl_xfer(9F), usb_pipe_close(9F), usb_pipe_get_state(9F), usb_pipe_intr_xfer(9F), usb_pipe_isoc_xfer(9F), usb_pipe_reset(9F), usb_pipe_set_private(9F), usb_ep_descr(9S), usb_callback_flags(9S)
