Solaris Smartcard Administration Guide
Resolving Smartcard Login Problems
If a user cannot log in to a system, you might need to disable Solaris Smartcard or correct a setup problem.
ProcedureTo Disable Smartcard
You might need to disable Smartcard on a system in the following instances:
Do the following to disable Solaris Smartcard.
Steps
  1. Verify that the ocfserv daemon is enabled.
    The following command provides the status of the service.
    % svcs network/rpc/ocfserv
    Note –
    Before you make any changes to Smartcard, you must make sure that the ocfserv daemon is enabled.
  2. (Optional) If necessary, as root, enable the ocfserv daemon.
    # svcadm enable network/rpc/ocfserv
  3. Disable smart-card operations.
    # smartcard -c disable
ProcedureTo Correct Smartcard Setup Problem
After you have enabled Smartcard and logged off from a system, the CDE login screen displays the following prompt:
Please insert Smart Card
If you are unable to log in to a system by using a smart card because of Smartcard setup problems, try the following:
Steps
  1. Log in to the system remotely with the rlogin or telnet command.
  2. Verify that the ocfserv daemon is enabled.
    Note –
  3. (Optional) If necessary, as root, enable the ocfserv daemon.
  4. Disable Smartcard:
    After Smartcard is disabled, the CDE screen displays the following prompt:
    Enter User Name
  5. Correct the Smartcard setup problem.
