Ports can be enabled or disabled depending on the state of the port monitor that controls the ports.
State |
Description |
Serial (ttymon) port states |
Enabled |
The ttymon port monitor sends a prompt message to the port and provides login service to it. |
Disabled |
Default state of all ports if ttymon is killed or disabled. If you specify this state, ttymon sends out the disabled message when it receives a connection request. |
