You can set up serial ports with the Solaris Management Console's Serial Ports tool.
Select a serial port from the Serial Ports window and then choose a Configure option from the Action menu to configure the following:
Terminal
Modem – Dial-In
Modem – Dial-Out
Modem – Dial-In/Dial-Out
Initialize Only– No Connection
The Configure options provide access to the templates for configuring these services. You can view two levels of detail for each serial port: Basic and Advanced. You can access the Advanced level of detail for each serial port after it is configured by selecting the serial port and selecting the Properties option from the Action menu. After a serial port is configured, you can disable or enable the port with the SAF commands. For information on using the SAF commands, see Chapter 3, Managing Serial Ports With the Service Access Facility (Tasks).
For information on using the Serial Ports command–line interface, see the smserialport(1M) man page.
The following table describes the menu items (and their default values) when you set up a terminal by using the Serial Ports tool.
Table 2–1 Terminal Default Values|
Detail |
Item |
Default Value |
Basic |
Port | |
Description |
Terminal |
Service Status |
Enabled |
Baud Rate |
9600 |
Terminal Type |
vi925 |
Login Prompt |
ttyn login: |
Advanced |
Carrier Detection |
Software |
Option: Connect on Carrier |
Not available |
Option: Bidirectional |
Available |
Option: Initialize Only |
Not available |
Timeout (seconds) |
Never |
Port Monitor |
zsmon |
Service Program |
/usr/bin/login |
The following table describes the three modem templates that are available when you set up a modem using the Serial Ports tool.
Table 2–2 Modem Templates|
Modem Configuration |
Description |
Dial-In Only |
Users can dial in to the modem but cannot dial out. |
Dial-Out Only |
Users can dial out from the modem but cannot dial in. |
Dial-In and Out (Bidirectional) |
Users can either dial in or dial out from the modem. |
The following table describes the default values of each template.
Table 2–3 Modem Template Default Values|
Detail |
Item |
Modem - Dial-In Only |
Modem - Dial-Out Only |
Modem - Dial In and Out |
Basic |
Port Name | |||
Description |
Modem – Dial In Only |
Modem – Dial Out Only |
Modem – Dial In and Out |
Service Status |
Enabled |
Enabled |
Enabled |
Baud Rate |
9600 |
9600 |
9600 |
Login Prompt |
ttyn login: |
ttyn login: |
ttyn login: |
Advanced |
Carrier Detection |
Software |
Software |
Software |
Not available |
Not available |
Not available |
Not available |
Not available |
Available |
Not available |
Available |
Not available |
Timeout (seconds) |
Never |
Never |
Never |
Port Monitor |
zsmon |
zsmon |
zsmon |
Service Program |
/usr/bin/login |
/usr/bin/login |
/usr/bin/login |
The following table describes the default values for the Initialize Only template.
Table 2–4 Initialize Only - No Connection Default Values|
Detail |
Item |
Default Value |
Basic |
Port Name |
Description |
Initialize Only - No Connection |
Service Status |
Enabled |
Baud Rate |
9600 |
Login Prompt |
ttyn login: |
Advanced |
Carrier Detection |
Software |
Not available |
Available |
Available |
Timeout (seconds) |
Never |
Port Monitor |
zsmon |
Service Program |
/usr/bin/login |
