System Administration Guide: Advanced Administration
Using the ps Command
The ps command enables you to check the status of active processes on a system, as well as display technical information about the processes. This data is useful for administrative tasks such as determining how to set process priorities.
Depending on which options you use, the ps command reports the following information:
The following table describes some fields that are reported by the ps command. Which fields are displayed depend on which option you choose. For a description of all available options, see the ps(1) man page.
Table 12–2 Summary of Fields in ps Reports
Field
Description
UID
The effective user ID of the process's owner.
PID
The process ID.
PPID
The parent process ID.
C
The processor xutilization for scheduling. This field is not displayed when the -c option is used.
CLS
The scheduling class to which the process belongs such as real-time, system, or timesharing. This field is included only with the -c option.
PRI
The kernel thread's scheduling priority. Higher numbers indicate a higher priority.
NI
The process's nice number, which contributes to its scheduling priority. Making a process “nicer” means lowering its priority.
ADDR
The address of the proc structure.
SZ
The virtual address size of the process.
WCHAN
The address of an event or lock for which the process is sleeping.
STIME
The starting time of the process in hours, minutes, and seconds.
TTY
The terminal from which the process, or its parent, was started. A question mark indicates that there is no controlling terminal.
TIME
The total amount of CPU time used by the process since it began.
CMD
The command that generated the process.
