This chapter describes the tasks that are required to display and change the most common system information.
For information about the procedures associated with displaying and changing system information, see the following:
For overview information about managing system resources, see Chapter 4, Managing System Resources (Overview).
Task |
Description |
For Instructions |
Determine whether a system has 32–bit or 64–bit capabilities enabled. |
Use the isainfo command to determine whether a system has 32–bit or 64-bit capabilities enabled. For x86 based systems, you can use the isalist command to display this information. |
How to Determine Whether a System Has 32–Bit or 64–Bit Capabilities Enabled |
Display Oracle Solaris release information. |
Display the contents of the /etc/release file to identify the Oracle Solaris release version. | |
Display general system information. |
Use the showrev command to display general system information. | |
Display a system's host ID number. |
Use the hostid command to display your system's host id. | |
Display a system's product name. |
Starting with the Solaris 10 1/06 release, you can use the prtconf -b command to display the product name of a system. | |
Display a system's installed memory. |
Use the prtconf command to display information about your system's installed memory. | |
Display a system's date and time. |
Use the date command to display your system's date and time. | |
Display a system's physical processor type. |
Use the psrinfo -p command to list the total number of physical processors on a system. Use the psrinfo -pv command to list all physical processors on a system and the virtual processors that is associated with each physical processor. | |
Display a system's logical processor type. |
Use the psrinfo -v command to display a system's logical processor type. | |
Display locales that are installed on a system. |
Use the localeadm command to display locales that are installed on your system. | |
Determine if a locale is installed on a system. |
Use the -q option of the localeadm command and a locale to determine if a locale is installed on your system. |
The following table describes commands that enable you to display general system information.
Table 5–1 Commands for Displaying System Information|
Command |
System Information Displayed |
Man Page |
date |
Date and time | |
hostid |
Host ID number | |
isainfo |
The number of bits supported by native applications on the running system, which can be passed as a token to scripts | |
isalist |
Processor type for x86 based systems | |
localeadm |
Locales installed on the system | |
prtconf |
System configuration information, installed memory, and product name | |
psrinfo |
Processor type | |
showrev |
Host name, host ID, release, kernel architecture, application architecture, hardware provider, domain, and kernel version | |
uname |
Operating system name, release, version, node name, hardware name, and processor type |
# isainfo options |
The isainfo command, run without specifying any options, displays the name or names of the native instruction sets for applications supported by the current OS version.
Prints detailed information about the other options.
Prints the number of bits in the address space of the native instruction set.
Prints the name of the native instruction set used by portable applications supported by the current version of the OS.
Prints the name of the instruction set or sets that are used by the OS kernel components such as device drivers and STREAMS modules.
For x86 based systems, the isalist command can also be used to display this information.
For more information, see the isalist(1) man page.
The isainfo command output for an UltraSPARC system that is running previous releases of the Oracle Solaris OS using a 32-bit kernel is displayed as follows:
$ isainfo -v 32-bit sparc applications |
This output means that this system can support only 32–bit applications.
The current release of the Oracle Solaris OS only ships a 64–bit kernel on SPARC based systems. The isainfo command output for an UltraSPARC system that is running a 64–bit kernel is displayed as follows:
$ isainfo -v 64-bit sparcv9 applications 32-bit sparc applications |
This output means that this system is capable of supporting both 32–bit and 64–bit applications.
Use the isainfo -b command to display the number of bits supported by native applications on the running system.
The output from a SPARC based, x86 based, or UltraSPARC system that is running the 32–bit Oracle Solaris OS is displayed as follows:
$ isainfo -b 32 |
The isainfo command output from a 64–bit UltraSPARC system that is running the 64–bit Oracle Solaris OS is displayed as follows:
$ isainfo -b 64 |
The command returns 64 only. Even though a 64–bit UltraSPARC system can run both types of applications, 64–bit applications are the best kind of applications to run on a 64–bit system.
The isainfo command output for an x86 based system that is running the 64-bit kernel is displayed as follows:
$ isainfo amd64 i386 |
This output means that this system can support 64–bit applications.
Use the isainfo -v command to determine if an x86 based system is capable of running a 32–bit kernel.
$ isainfo -v
64-bit amd64 applications
fpu tsc cx8 cmov mmx ammx a3dnow a3dnowx fxsr sse sse2
32-bit i386 applications
This output means that this system can support both 64–bit and 32–bit applications.
The output from an x86 based system that is running the 32–bit Oracle Solaris OS is displayed as follows:
$ isainfo -b 32 |
The isainfo command output from an x86 based system that is running the 64–bit Oracle Solaris OS is displayed as follows:
$ isainfo -b 64 |
You can also use the isalist command to determine whether an x86 based system is running in 32–bit or 64–bit mode.
$ isalist amd64 pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86 |
In the preceding example, amd64 indicates that the system has 64–bit capabilities enabled.
Display the contents of the /etc/release file to identify your release version.
$ cat /etc/release
Solaris 10 s10_51 SPARC
Copyright 2004 Sun Microsystems, Inc. All Rights Reserved.
Use is subject to license terms.
Assembled 21 January 2004
To display general system information, use the showrev command.
$ showrev options |
Prints all system revision information available.
Prints the revision information about command.
Prints only the revision information about patches.
Defines the full path name of a directory to use as the root_path.
Performs this operation on the specified host name.
Prints only the OpenWindows revision information.
You can also use the uname command to display system information. The following example shows the uname command output. The -a option displays the operating system name as well as the system node name, operating system release, operating system version, hardware name, and processor type.
$ uname SunOS $ uname -a SunOS starbug 5.10 Generic sun4u sparc SUNW,Ultra-5_10 $ |
The following example shows the showrev command output. The -a option displays all available system information.
$ showrev -a Hostname: stonetouch Hostid: 8099dfb9 Release: 5.10 Kernel architecture: sun4u Application architecture: sparc Hardware provider: Sun_Microsystems Domain: boulder.Central.Sun.COM Kernel version: SunOS 5.10 s10_46 OpenWindows version: Solaris X11 Version 6.6.2 20 October 2003 No patches are installed |
The following example shows sample output from the hostid command.
$ hostid 80a5d34c |
Solaris 10 1/06: The -b option to the prtconf command enables you to display a system's product name. For more information on this feature, see the prtconf(1M) man page.
To display the product name for your system, use the prtconf command with the -b option, as follows:
% prtconf -b |
This example shows sample output from the prtconf -b command.
$ prtconf -b name: SUNW,Ultra-5_10 model: SUNW,375-0066 banner-name: Sun Ultra 5/10 UPA/PCI (UltraSPARC-IIi 333MHz) |
This example shows sample output from the prtconf -vb command.
$ prtconf -vb name: SUNW,Ultra-5_10 model: SUNW,375-0066 banner-name: Sun Ultra 5/10 UPA/PCI (UltraSPARC-IIi 333MHz) idprom: 01800800.20a6c363.00000000.a6c363a9.00000000.00000000.405555aa.aa555500 openprom model: SUNW,3.15 openprom version: 'OBP 3.15.2 1998/11/10 10:35' |
The following example shows sample output from the prtconf command. The grep Memory command selects output from the prtconf command to display memory information only.
$ prtconf | grep Memory Memory size: 128 Megabytes |
The following example shows sample output from the date command.
$ date Wed Jan 21 17:32:59 MST 2004 $ |
Use the psrinfo -p command to display the total number of physical processors on a system.
$ psrinfo -p 1 |
Use the psrinfo -pv command to display information about each physical processor on a system, and the virtual processor associated with each physical processor.
$ psrinfo -pv The UltraSPARC-IV physical processor has 2 virtual processors (8, 520) The UltraSPARC-IV physical processor has 2 virtual processors (9, 521) The UltraSPARC-IV physical processor has 2 virtual processors (10, 522) The UltraSPARC-IV physical processor has 2 virtual processors (11, 523) The UltraSPARC-III+ physical processor has 1 virtual processor (16) The UltraSPARC-III+ physical processor has 1 virtual processor (17) The UltraSPARC-III+ physical processor has 1 virtual processor (18) The UltraSPARC-III+ physical processor has 1 virtual processor (19) |
When you use the psrinfo -pv command on an x86 based system, the following output is displayed:
$ psrinfo -pv The i386 physical processor has 2 virtual processors (0, 2) The i386 physical processor has 2 virtual processors (1, 3) |
Use the psrinfo -v command to display information about a system's processor type.
$ psrinfo -v |
On an x86 based system, use the isalist command to display the virtual processor type.
$ isalist |
This example shows how to display information about a SPARC based system's processor type.
$ psrinfo -v Status of virtual processor 0 as of: 04/16/2004 10:32:13 on-line since 03/22/2004 19:18:27. The sparcv9 processor operates at 650 MHz, and has a sparcv9 floating point processor. |
This example shows how to display information about an x86 based system's processor type.
$ isalist pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86 |
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Display the locales currently installed on your system using the localeadm command. The -l option displays the locales that are installed on the system. For example:
# localeadm -l Checking for installed pkgs. This could take a while. Checking for Australasia region (aua) (1of2 pkgs) |......| . . . The following regions are installed on concordance on Wed Dec 17 15:13:00 MST 2003 POSIX (C) Central Europe (ceu) [ Austria, Czech Republic, Germany, Hungary, Poland, Slovakia, Switzerland (German), Switzerland (French) ] Done. |
Determine if a locale is installed on your system using the localeadm command. The -q option and a locale queries the system to see if that locale is installed on the system. To see if the Central European region (ceu) is installed on your system, for example:
# localeadm -q ceu locale/region name is ceu Checking for Central Europe region (ceu) . . . The Central Europe region (ceu) is installed on this system |
This section describes commands that enable you to change general system information.
Enter the new date and time.
# date mmddHHMM[[cc]yy] |
Month, using two digits.
Day of the month, using two digits.
Hour, using two digits and a 24-hour clock.
Minutes, using two digits.
Century, using two digits.
Year, using two digits.
See the date(1) man page for more information.
Verify that you have reset your system's date correctly by using the date command with no options.
The following example shows how to use the date command to manually set a system's date and time.
# date Wed Mar 3 14:04:19 MST 2004 # date 0121173404 Thu Jan 21 17:34:34 MST 2004 |
Edit the message-of-the-day file, /etc/motd, to include announcements or inquiries to all users of a system when they log in. Use this feature sparingly, and edit this file regularly to remove obsolete messages.
Edit the /etc/motd file and add a message of your choice.
Edit the text to include the message that will be displayed during user login. Include spaces, tabs, and carriage returns.
Verify the changes by displaying the contents of the /etc/motd file.
$ cat /etc/motd Welcome to the UNIX Universe. Have a nice day. |
The default message-of-the-day, which is provided when you install Oracle Solaris software, contains version information.
$ cat /etc/motd Sun Microsystems Inc. SunOS 5.10 Generic May 2004 |
The following example shows an edited /etc/motd file that provides information about system availability to each user who logs in.
$ cat /etc/motd The system will be down from 7:00 a.m to 2:00 p.m. on Saturday, July 7, for upgrades and maintenance. Do not try to access the system during those hours. Thank you. |
A system's host name is specified in several different locations.
Remember to update your name service database to reflect the new host name.
Use the following procedure to change or rename a system's host name.
You can also use the sys-unconfig command to reconfigure a system, including the host name. For more information, see the sys-unconfig(1M) man page.
Change the system's host name in the following files:
/etc/nodename
/etc/hostname.*interface
/etc/inet/hosts
/etc/inet/ipnodes (Applies only to some releases)
Starting with the Solaris 10 8/07 release, there is no longer two separate hosts files. The /etc/inet/hosts file is the single hosts file that contains both IPv4 and IPv6 entries. You do not need to maintain IPv4 entries in two hosts files that always require synchronization. For backward compatibility, the /etc/inet/ipnodes file is replaced with a symbolic link of the same name to the /etc/inet/hosts file. For more information, see the hosts(4) man page.
(Optional) If you are using a name service, change the system's host name in the hosts file.
Rename the host name directory within the /var/crash directory.
# cd /var/crash # mv old-host-name new-host-name |
Reboot the system to activate the new host name.
# init 6 |
Add the packages for the locale you want to install on your system using the localeadm command.
The -a option and a locale identifies the locale that you want to add. The -d option and a device identifies the device containing the locale packages you want to add. To add the Central European region (ceu) to your system, for example:
# localeadm -a ceu -d /net/install/latest/Solaris/Product locale/region name is ceu Devices are /net/install/latest/Solaris/Product . . . One or more locales have been added. To update the list of locales available at . . . |
Remove the packages for the locale installed on your system using the localeadm command.
The -r option and a locale identifies the locale that you want to remove from the system. To remove the Central European region (ceu) from your system, for example:
# localeadm -r ceu locale/region name is ceu Removing packages for Central Europe (ceu) . . . One or more locales have been removed. To update the list of locales available at the login screen's "Options->Language" menu, . . . |
