The error messages in this section might be displayed in any phase after initialization. Although they offer the option to continue, it is generally best to regard them as fatal. They reflect a serious system failure and should be handled immediately. When confronted with such a message, terminate the program by entering n(o). If you cannot determine what caused the problem, contact your local service provider or another qualified person.
CANNOT SEEK: BLK disk-block-number (CONTINUE) |
Oracle Solaris 10:
CANNOT SEEK: BLK block-number (CONTINUE) |
A request to move to the specified block number, disk-block-number, in the file system failed. This message indicates a serious problem, probably a hardware failure.
Oracle Solaris 10: A request to move to the specified block number, block-number, in the file system failed. This message indicates a serious problem, probably a hardware failure.
If you want to continue the file system check, fsck will retry the move and display a list of sector numbers that could not be moved. If the block was part of the virtual memory buffer cache, fsck will terminate with a fatal I/O error message.
If the disk is experiencing hardware problems, the problem will persist. Run fsck again to recheck the file system.
If the recheck fails, contact your local service provider or another qualified person.
CANNOT READ: DISK BLOCK disk-block-number: I/O ERROR CONTINUE? |
Oracle Solaris 10:
CANNOT READ: DISK BLOCK block-number: I/O ERROR CONTINUE? |
A request to read the specified block number, disk-block-number, in the file system failed. The message indicates a serious problem, probably a hardware failure.
Oracle Solaris 10: A request to read a specified block number, block-number, in the file system failed. The message indicates a serious problem, probably a hardware failure.
If you want to continue the file system check, fsck will retry the read and display a list of sector numbers that could not be read. If the block was part of the virtual memory buffer cache, fsck will terminate with a fatal I/O error message. If fsck tries to write back one of the blocks on which the read failed, it will display the following message:
WRITING ZERO'ED BLOCK sector-numbers TO DISK
If the disk is experiencing hardware problems, the problem will persist. Run fsck again to recheck the file system. If the recheck fails, contact your local service provider or another qualified person.
CANNOT WRITE: BLK disk-block-number (CONTINUE) |
Oracle Solaris 10:
CANNOT WRITE: BLK block-number (CONTINUE) |
A request to write the specified block number, disk-block-number, in the file system failed.
If you continue the file system check, fsck will retry the write and display a list of sector numbers that could not be written. If the block was part of the virtual memory buffer cache, fsck will terminate with a fatal I/O error message.
Oracle Solaris 10: A request to write a specified block number, block-number, in the file system failed.
The disk might be write-protected. Check the write-protect lock on the drive. If the disk has hardware problems, the problem will persist. Run fsck again to recheck the file system. If the write-protect is not the problem or the recheck fails, contact your local service provider or another qualified person.
