System Administration Guide: Advanced Administration
What to Do If File ACLs Are Lost After Copy or Restore
Reason Error Occurred
How to Fix the Problem
If files or directories with ACLs are copied or restored into the /tmp directory, the ACL attributes are lost. The /tmp directory is usually mounted as a temporary file system, which doesn't support UFS file system attributes such as ACLs.
Copy or restore files into the /var/tmp directory instead.
