Oracle Solaris Tunable Parameters Reference Manual
New or Changed Parameters in the Solaris 10 Release
The following sections describe new, changed, or obsolete kernel tunables.
Solaris Kernel Tunable Parameters
General Kernel and Memory Parameters
The parameter, default_stksize, is new in the Solaris 10 release.
The lwp_default_stksize and noexec_user_stack parameters are changed in this release.
UFS
The following parameters are modified in the Solaris 10 release:
General File System
The following parameters are newly documented in the Solaris 10 release:
System V Message Queues
The following parameters have been removed in the Solaris 10 release:
The following parameters are obsolete as of the Solaris 10 release:
System V Semaphores
System V Shared Memory
The following parameters have been removed from the Solaris 10 release:
The following parameters are obsolete.
TSB Parameters
The following TSB parameters are new in the Solaris 10 release:
NFS Parameters
The stability level of all NFS parameters was changed from “Evolving” to “Unstable.”
The following NFSv4 parameters are new in the Solaris 10 release:
The following NFS parameters are new or changed in the Solaris 10 release:
The following NFS parameters were previously provided in error and have been removed:
TCP/IP Parameters
The following IP parameters are new in the Solaris 10 release:
The following TCP parameters are new in this Solaris release:
The following TCP/IP parameters are obsolete in the Solaris 10 release:
SCTP Tunable Parameters
The following SCTP parameters are new in the Solaris 10 release:
System Facility Parameters
The following system facilities are new in the Solaris 10 release:
The inetd system facility is obsolete in the Solaris 10 release.
Removal of sun4m Support
The sun4m platform is not supported in the Solaris 10 release. The following parameters were modified to reflect the removal of sun4m support:
