The Solaris Management Console is a container for GUI-based management tools that are stored in collections referred to as toolboxes.
The console includes a default toolbox with many basic management tools, including tools for managing the following:
Users
Projects
cron jobs for mounting and sharing file systems
cron jobs for managing disks and serial ports
For a brief description of each Solaris management tool, see Table 2–1.
You can add tools to the existing toolbox, or you can create new toolboxes.
The Solaris Management Console has three primary components:
The Solaris Management Console client
Called the console, this component is the visible interface and contains the GUI tools that are used to perform management tasks.
The Solaris Management Console server
This component is located either on the same system as the console or it is remote. This component provides all of the back-end functionality that enables management through the console.
The Solaris Management Console toolbox editor
This application, which appears similar to the console, is used to add or modify toolboxes, to add tools to a toolbox, or to extend the scope of a toolbox. For example, you could add a toolbox to manage a name service domain.
The default toolbox is visible when you start the console.
