Task |
Description |
For Instructions |
2. (Optional) Specify a web proxy. |
If your system is behind a firewall with a web proxy, you must specify the web proxy to obtain patches from the patch server. | |
3. Download and apply a patch. |
You can download and apply a patch to your system by using the patchadd command. | |
4. (Optional) Display information about patches that have been applied to your system. |
If you want information about the patches that have already been applied to your system, use the patchadd, showrev, or pkgparam command. | |
5. (Optional) Remove a patch from your system. |
If necessary, remove a patch from your system by using the patchrm command. |
If your system is behind a firewall with a web proxy, you must specify the web proxy to use patchadd to apply a patch.
Become superuser or assume an equivalent role.
Use one of the following methods to specify a web proxy:
Specify the web proxy by using the http_proxy, HTTPPROXY, or HTTPPROXYPORT environment variable.
For example:
# setenv http_proxy http://mycache.domain:8080 |
Or, specify one of the following:
# setenv HTTPPROXY mycache.domain # setenv HTTPPROXYPORT 8080 |
Specify the web proxy on the patchadd command line.
For example:
# patchadd -x mycache.domain:8080 \ -M http://www.sun.com/solaris/patches/latest 101223-02 102323-02 |
On systems that are running an Oracle Solaris release that is not zones aware, using the patchadd command, or any command that accepts the -R option to specify an alternate root path for a global zone that has non-global zones installed, does not work.
You can use of the -R option to add and remove software packages and patches, if the alternate boot environment has configured non-global zones, but no installed non-global zones.
To avoid a potential problem, restrict the use of the -R option for the creation of an alternate root path.
If you are running Oracle Solaris 10, you can alternately choose one of the following methods:
Upgrade any systems that are not running at least the Solaris 10 1/06 OS.
If you are running the Oracle Solaris 10 initial 3/05 release, you can install the following patch to enable the use of commands that accept the -R option for creation of an alternate root path.
For SPARC based systems – Install at least revision 19 of patch 119254.
For x86 based systems – Install at least revision 19 patch 119255.
Boot an alternate root, for example the Oracle Solaris OS, as the active OS. You can then install and uninstall packages and patches without using the -R option.
For more information, see the patchadd(1M), patchrm(1M), pkgadd(1M), and pkgrm(1M) man pages.
Use this procedure to download an unsigned Solaris patch and then apply it to your system.
If you want to apply signed patches, you must first set up the package keystore. For more information, go to http://download.oracle.com/docs/cd/E17476_01/javase/1.4.2/docs/tooldocs/solaris/keytool.html.
Gain access to the system in one of the following ways:
Start a web browser and go to the SunSolve Online Patch Portal at http://sunsolve.Sun.COM.
Determine whether to download a specific patch or a patch cluster, then do one of the following:
Type the patch number (patch-id) in the Find Patch search field, then click Find Patch.
Entering patch-id downloads the latest patch revision.
If this patch is freely available, the patch README appears. If this patch is not freely available, an ACCESS DENIED message appears.
Note that patch numbers for SPARC based and x86 based systems are different. The patch IDs are listed in the patch README. Ensure that you apply the patch that matches your system architecture.
Select the Recommended Patch Cluster that matches the Oracle Solaris release that is running on the system that you want to patch.
Download the patch by following these instructions:
To download a copy of the signed patch, click the Download Signed Patch (n bytes) button.
To download an unsigned patch, click the Download Patch ( n bytes) button.
When the patch or patches are successfully downloaded, close the web browser.
Change to the directory that contains the downloaded patch.
(Unsigned patch) If you downloaded an unsigned patch, unzip the patch.
# unzip patch-id |
Apply the signed or unsigned patch.
For example:
# patchadd /tmp/111879-01 |
If you downloaded a signed patch, apply it.
For example:
# patchadd /tmp/111879-01.jar |
If you downloaded an unsigned patch, apply it.
For example:
Verify that the patch has been successfully applied.
For example:
# patchadd -p | grep 111879 Patch: 111879-01 Obsoletes: Requires: Incompatibles: Packages: SUNWwsr |
Before applying patches, you might want to know more about patches that have been previously applied.
The following commands provide useful information about patches that are already applied to a system.
patchadd -p or showrev -p
Shows all patches that have been applied to the system.
pkgparam pkgid PATCHLIST
Shows all patches that have been applied to the package identified by pkgid, for example, SUNWadmap.
patchadd -S Oracle-Solaris-OS -p
Shows all the /usr patches that have been applied to an OS server.
Use one of the following patchadd command lines to display information about patches that have been applied to your system.
To obtain information about all patches that have been applied to your system, type:
$ patchadd -p |
To verify whether a particular patch has been applied to your system, type, for example:
$ patchadd -p | grep 111879 |
