Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Remove an installed package.
# pkgrm pkgid ... |
pkgid identifies the name of one or more packages, separated by spaces, to be removed. If omitted, the pkgrmcommand removes all available packages.
This example shows how to remove a package.
# pkgrm SUNWctu
The following package is currently installed:
SUNWctu Netra ct usr/platform links (64-bit)
(sparc.sun4u) 11.9.0,REV=2001.07.24.15.53
Do you want to remove this package? y
## Removing installed package instance <SUNWctu>
## Verifying package dependencies.
## Processing package information.
## Removing pathnames in class <none>
This example shows how to remove a spooled package.
# pkgrm -s /export/pkg SUNWaudh
The following package is currently spooled:
SUNWaudh Audio Header Files
(sparc) 11.10.0,REV=2003.08.08.00.03
Removing spooled package instance <SUNWaudh>
