To insert characters with diacritical marks or special characters from Latin-1, Latin-2, Latin-4, Latin-5, and Latin-9, you must type a Compose key sequence, as described in the following examples.
To display the Ä character:
Press and release the Compose key.
Press Shift and the A key simultaneously. Release Shift-A.
Press and release the ” key.
To display the ¿, character:
Press and release the ? key.
When there is no Compose key available on your keyboard, you can emulate its operation by simultaneously pressing the Control key and the Shift key.
For the input of the Euro currency symbol (Unicode value U+20AC) from the locale, you can use any one of following input sequences:
AltGraph and E together
AltGraph and 4 together
AltGraph and 5 together
With these input sequences, you press both keys simultaneously. If no AltGraph key is available on your keyboard, you can use certain alternative euro sign input sequences such as Compose e = or Compose c =.
The following tables show the most commonly used compose sequences for Latin-1, Latin-2, Latin-3, Latin-4, Latin-5, and Latin-9 script input for the Oracle Solaris operating system.
The following table lists the common Latin-1 Compose key sequences.
Table A–1 Common Latin-1 Compose Key Sequences|
 Press Compose, then Press and Release  |
 Press and Release  |
 Result  |
 spacebar  |
 spacebar  |
 no-break space  |
 s  |
 1  |
 superscripted 1  |
 s  |
 2  |
 superscripted 2  |
 s  |
 3  |
 superscripted 3  |
 inverted exclamation mark  |
 x  |
 o  |
 currency symbol ¤  |
 p  |
 paragraph symbol ¶  |
 u  |
 mu u  |
 acute accent ´  |
 , (comma)  |
 cedilla Ç  |
 diaeresis ¨  |
 macron ¯  |
 o  |
 o  |
 degree °  |
 x  |
 x  |
 multiplication sign x  |
 plus-minus ±  |
 soft hyphen –  |
 division sign ÷  |
 a  |
 ordinal (feminine) ª  |
 o  |
 ordinal (masculine) º  |
 , (comma)  |
 not sign ¬  |
 middle dot ·  |
 1  |
 2  |
 vulgar fraction ½  |
 1  |
 4  |
 vulgar fraction ¼  |
 3  |
 4  |
 vulgar fraction ¾  |
 left double angle quotation mark «  |
 right double angle quotation mark »  |
 inverted question mark ¿  |
 A  |
 ` (backquote)  |
 A grave À  |
 A  |
 ' (single quote)  |
 A acute Á  |
 A  |
 A ring above Å  |
 A  |
 A diaeresis Ä  |
 A  |
 A circumflex   |
 A  |
 A tilde à |
 A  |
 E  |
 AE diphthong Æ  |
 C  |
 , (comma)  |
 C cedilla Ç  |
 C  |
 o  |
 copyright sign ©  |
 D  |
 Capital eth ð  |
 E  |
 ` (backquote)  |
 E grave È  |
 E  |
 E acute É  |
 E  |
 E diaeresis Ë  |
 E  |
 E circumflex Ê  |
 I  |
 ` (backquote)  |
 I grave Ì  |
 I  |
 I acute Í  |
 I  |
 I diaeresis Ï  |
 I  |
 I circumflex Î  |
 L  |
 pound sign £  |
 N  |
 N tilde Ñ  |
 O  |
 ` (backquote)  |
 O grave Ò  |
 O  |
 O acute Ó  |
 O  |
 O slash Ø  |
 O  |
 O diaeresis Ö  |
 O  |
 O circumflex Ô  |
 O  |
 O tilde Õ  |
 R  |
 O  |
 registered mark ®  |
 T  |
 H  |
 Thorn þ  |
 U  |
 ` (backquote)  |
 U grave Ù  |
 U  |
 U acute Ú  |
 U  |
 U diaeresis Ü  |
 U  |
 U circumflex Û  |
 Y  |
 Y acute ý  |
 Y  |
 yen sign ¥  |
 a  |
 ` (backquote)  |
 a grave à  |
 a  |
 a acute á  |
 a  |
 a ring above å  |
 a  |
 a diaeresis ä  |
 a  |
 a tilde ã  |
 a  |
 a circumflex â  |
 a  |
 e  |
 ae diphthong æ  |
 c  |
 , (comma)  |
 c cedilla ç  |
 c  |
 cent sign ¢  |
 c  |
 o  |
 copyright sign ©  |
 d  |
 eth ð  |
 e  |
 ` (backquote)  |
 e grave è  |
 e  |
 e acute é  |
 e  |
 e diaeresis ë  |
 e  |
 e circumflex ê  |
 i  |
 ` (backquote)  |
 i grave ì  |
 i  |
 i acute í  |
 i  |
 i diaeresis ï  |
 i  |
 i circumflex î  |
 n  |
 n tilde ñ  |
 o  |
 ` (backquote)  |
 o grave ò  |
 o  |
 o acute ó  |
 o  |
 o slash ø  |
 o  |
 o diaeresis ö  |
 o  |
 o circumflex ô  |
 o  |
 o tilde õ  |
 s  |
 s  |
 German double s ß also known as sharp S  |
 t  |
 h  |
 thorn þ  |
 u  |
 ` (backquote)  |
 u grave ù  |
 u  |
 u acute ú  |
 u  |
 u diaeresis ü  |
 u  |
 u circumflex û  |
 y  |
 y acute y  |
 y  |
 y diaeresis ÿ  |
 broken bar ¦  |
The following table lists the common Latin-2 Compose key sequences.
Table A–2 Common Latin-2 Compose Key Sequences|
 Press and Release  |
 Result  |
 k  |
 k  |
 kra  |
 A  |
 _  |
 A macron  |
 E  |
 _  |
 E macron  |
 E  |
 E dot above  |
 G  |
 G cedilla  |
 I  |
 _  |
 I macron  |
 I  |
 I tilde  |
 I  |
 a  |
 I ogonek  |
 K  |
 K cedilla  |
 L  |
 L cedilla  |
 N  |
 N cedilla  |
 O  |
 _  |
 O macron  |
 R  |
 R cedilla  |
 T  |
 T stroke  |
 U  |
 U tilde  |
 U  |
 a  |
 U ogonek  |
 U  |
 _  |
 U macron  |
 N  |
 N  |
 Eng  |
 a  |
 _  |
 a macron  |
 e  |
 _  |
 e macron  |
 e  |
 e dot above  |
 g  |
 g cedilla  |
 i  |
 _  |
 i macron  |
 i  |
 i tilde  |
 i  |
 a  |
 i ogonek  |
 k  |
 k cedilla  |
 l  |
 l cedilla  |
 n  |
 n cedilla  |
 o  |
 _  |
 o macron  |
 r  |
 r cedilla  |
 t  |
 t stroke  |
 u  |
 u tilde  |
 u  |
 a  |
 u ogonek  |
 u  |
 _  |
 u macron  |
 n  |
 n  |
 eng  |
The following table lists the common Latin-3 Compose key sequences.
Table A–3 Common Latin-3 Compose Key Sequences|
 Press and Release  |
 Result  |
 C  |
 C circumflex  |
 C  |
 C dot above  |
 G  |
 G circumflex  |
 G  |
 G dot above  |
 H  |
 H circumflex  |
 J  |
 j circumflex  |
 S  |
 S circumflex  |
 U  |
 u  |
 U breve  |
 c  |
 c circumflex  |
 c  |
 c dot above  |
 g  |
 g circumflex  |
 g  |
 g dot above  |
 h  |
 h circumflex  |
 j  |
 j circumflex  |
 s  |
 s circumflex  |
 u  |
 u  |
 u breve  |
The following table lists the common Latin-4 Compose key sequences.
Table A–4 Common Latin-4 Compose Key Sequences|
 Press and Release  |
 Result  |
 k  |
 k  |
 kra  |
 A  |
 _  |
 A macron  |
 E  |
 _  |
 E macron  |
 E  |
 E dot above  |
 G  |
 G cedilla  |
 I  |
 _  |
 I macron  |
 I  |
 I tilde  |
 I  |
 a  |
 I ogonek  |
 K  |
 K cedilla  |
 L  |
 L cedilla  |
 N  |
 N cedilla  |
 O  |
 _  |
 O macron  |
 R  |
 R cedilla  |
 T  |
 T stroke  |
 U  |
 U tilde  |
 U  |
 a  |
 U ogonek  |
 U  |
 _  |
 U macron  |
 N  |
 N  |
 Eng  |
 a  |
 _  |
 a macron  |
 e  |
 _  |
 e macron  |
 e  |
 e dot above  |
 g  |
 g cedilla  |
 i  |
 _  |
 i macron  |
 i  |
 i tilde  |
 i  |
 a  |
 i ogonek  |
 k  |
 k cedilla  |
 l  |
 l cedilla  |
 n  |
 n cedilla  |
 o  |
 _  |
 o macron  |
 r  |
 r cedilla  |
 t  |
 t stroke  |
 u  |
 u tilde  |
 u  |
 a  |
 u ogonek  |
 u  |
 _  |
 u macron  |
 n  |
 n  |
 eng  |
The following table lists the common Latin-5 Compose key sequences.
Table A–5 Common Latin-5 Compose Key Sequences|
 Press and Release  |
 Result  |
 G  |
 u  |
 G breve  |
 I  |
 I dot above  |
 g  |
 u  |
 g breve  |
 i  |
 i dotless  |
The following table lists the Common Latin-9 Compose key sequences.
Table A–6 Common Latin-9 Compose Key Sequences|
 Press and Release  |
 Result  |
 o  |
 e  |
 Ligature oe  |
 O  |
 E  |
 Ligature OE  |
 Y  |
 Y diaeresis  |
If you are using a keyboard that has accent dead keys, use the following compose key sequences. The dead_acute key name comes from the X11 registered keysym names of X_dead_acute as shown at /usr/openwin/include/X11/keysymdef.h. The SunFA_Circum and such key names come from X11 keysym names such as SunXK_FA_Circum shown at /usr/openwin/include/X11/Sunkeysym.h.
Table A–7 Compose Key Sequences Based on Accent Dead Keys|
 Press and Release  |
 Press and Release  |
 Result  |
 dead_grave  |
 spacebar  |
 grave accent  |
 dead_acute  |
 apostrophe  |
 acute accent  |
 dead_acute  |
 spacebar  |
 apostrophe  |
 dead_diaeresis  |
 double quote  |
 diaeresis  |
 dead_diaeresis  |
 spacebar  |
 diaeresis  |
 dead_circumflex  |
 spacebar  |
 circumflex accent  |
 dead_circumflex  |
 slash  |
 vertical line  |
 dead_circumflex  |
 0  |
 degree sign  |
 dead_circumflex  |
 1  |
 superscript one  |
 dead_circumflex  |
 2  |
 superscript two  |
 dead_circumflex  |
 3  |
 superscript three  |
 dead_circumflex  |
 period  |
 middle dot  |
 dead_circumflex  |
 exclamation point  |
 broken bar  |
 dead_circumflex  |
 minus  |
 macron  |
 dead_circumflex  |
 underscore  |
 macron  |
 dead_cedilla  |
 comma  |
 cedilla  |
 dead_cedilla  |
 minus  |
 not sign  |
 dead_tilde  |
 spacebar  |
 tilde  |
 dead_grave  |
 A  |
 A with grave  |
 dead_acute  |
 A  |
 A with acute  |
 dead_circumflex  |
 A  |
 A with circumflex  |
 dead_tilde  |
 A  |
 A with tilde  |
 dead_diaeresis  |
 A  |
 A with diaeresis  |
 dead_grave  |
 a  |
 a with grave  |
 dead_acute  |
 a  |
 a with acute  |
 dead_circumflex  |
 a  |
 a with circumflex  |
 dead_tilde  |
 a  |
 a with tilde  |
 dead_diaeresis  |
 a  |
 a with diaeresis  |
 dead_cedilla  |
 C  |
 C with cedilla  |
 dead_cedilla  |
 c  |
 c with cedilla  |
 dead_grave  |
 E  |
 E with grave  |
 dead_acute  |
 E  |
 E with acute  |
 dead_circumflex  |
 E  |
 E with circumflex  |
 dead_diaeresis  |
 E  |
 E with diaeresis  |
 dead_grave  |
 e  |
 e with grave  |
 dead_acute  |
 e  |
 e with acute  |
 dead_circumflex  |
 e  |
 e with circumflex  |
 dead_diaeresis  |
 e  |
 e with diaeresis  |
 dead_grave  |
 I  |
 I with grave  |
 dead_acute  |
 I  |
 I with acute  |
 dead_circumflex  |
 I  |
 I with circumflex  |
 dead_diaeresis  |
 I  |
 I with diaeresis  |
 dead_grave  |
 i  |
 i with grave  |
 dead_acute  |
 i  |
 i with acute  |
 dead_circumflex  |
 i  |
 i with circumflex  |
 dead_diaeresis  |
 i  |
 i with diaeresis  |
 dead_tilde  |
 N  |
 N with tilde  |
 dead_tilde  |
 n  |
 n with tilde  |
 dead_grave  |
 O  |
 O with grave  |
 dead_acute  |
 O  |
 O with acute  |
 dead_circumflex  |
 O  |
 O with circumflex  |
 dead_tilde  |
 O  |
 O with tilde  |
 dead_diaeresis  |
 O  |
 O with diaeresis  |
 dead_grave  |
 o  |
 o with grave  |
 dead_acute  |
 o  |
 o with acute  |
 dead_circumflex  |
 o  |
 o with circumflex  |
 dead_tilde  |
 o  |
 o with tilde  |
 dead_diaeresis  |
 o  |
 o with diaeresis  |
 dead_cedilla  |
 S  |
 S with cedilla  |
 dead_cedilla  |
 s  |
 s with cedilla  |
 dead_grave  |
 U  |
 U with grave  |
 dead_acute  |
 U  |
 U with acute  |
 dead_circumflex  |
 U  |
 U with circumflex  |
 dead_diaeresis  |
 U  |
 U with diaeresis  |
 dead_grave  |
 u  |
 u with grave  |
 dead_acute  |
 u  |
 u with acute  |
 dead_circumflex  |
 u  |
 u with circumflex  |
 dead_diaeresis  |
 u  |
 u with diaeresis  |
 dead_acute  |
 Y  |
 Y with acute  |
 dead_acute  |
 y  |
 y with acute  |
 dead_diaeresis  |
 y  |
 y with diaeresis  |
 SunFA_Grave  |
 spacebar  |
 grave accent  |
 SunFA_Grave  |
 A  |
 A with grave  |
 SunFA_Grave  |
 a  |
 a with grave  |
 SunFA_Grave  |
 E  |
 E with grave  |
 SunFA_Grave  |
 e  |
 e with grave  |
 SunFA_Grave  |
 I  |
 I with grave  |
 SunFA_Grave  |
 i  |
 i with grave  |
 SunFA_Grave  |
 O  |
 O with grave  |
 SunFA_Grave  |
 o  |
 o with grave  |
 SunFA_Grave  |
 U  |
 U with grave  |
 SunFA_Grave  |
 u  |
 u with grave  |
 SunFA_Acute  |
 apostrophe  |
 acute accent  |
 SunFA_Acute  |
 spacebar  |
 apostrophe  |
 SunFA_Acute  |
 A  |
 A with acute  |
 SunFA_Acute  |
 a  |
 a with acute  |
 SunFA_Acute  |
 C  |
 C with acute  |
 SunFA_Acute  |
 c  |
 c with acute  |
 SunFA_Acute  |
 E  |
 E with acute  |
 SunFA_Acute  |
 e  |
 e with acute  |
 SunFA_Acute  |
 I  |
 I with acute  |
 SunFA_Acute  |
 i  |
 i with acute  |
 SunFA_Acute  |
 L  |
 L with acute  |
 SunFA_Acute  |
 l  |
 l with acute  |
 SunFA_Acute  |
 N  |
 N with acute  |
 SunFA_Acute  |
 n  |
 n with acute  |
 SunFA_Acute  |
 O  |
 O with acute  |
 SunFA_Acute  |
 o  |
 o with acute  |
 SunFA_Acute  |
 R  |
 R with acute  |
 SunFA_Acute  |
 r  |
 r with acute  |
 SunFA_Acute  |
 S  |
 S with acute  |
 SunFA_Acute  |
 s  |
 s with acute  |
 SunFA_Acute  |
 U  |
 U with acute  |
 SunFA_Acute  |
 u  |
 u with acute  |
 SunFA_Acute  |
 Y  |
 Y with acute  |
 SunFA_Acute  |
 y  |
 y with acute  |
 SunFA_Acute  |
 Z  |
 Z with acute  |
 SunFA_Acute  |
 z  |
 z with acute  |
 SunFA_Cedilla  |
 comma  |
 cedilla  |
 SunFA_Cedilla  |
 minus  |
 not sign  |
 SunFA_Cedilla  |
 C  |
 C with cedilla  |
 SunFA_Cedilla  |
 c  |
 c with cedilla  |
 SunFA_Cedilla  |
 G  |
 G with cedilla  |
 SunFA_Cedilla  |
 g  |
 g with cedilla  |
 SunFA_Cedilla  |
 K  |
 K with cedilla  |
 SunFA_Cedilla  |
 k  |
 k with cedilla  |
 SunFA_Cedilla  |
 L  |
 L with cedilla  |
 SunFA_Cedilla  |
 l  |
 l with cedilla  |
 SunFA_Cedilla  |
 N  |
 N with cedilla  |
 SunFA_Cedilla  |
 n  |
 n with cedilla  |
 SunFA_Cedilla  |
 R  |
 R with cedilla  |
 SunFA_Cedilla  |
 r  |
 r with cedilla  |
 SunFA_Cedilla  |
 S  |
 S with cedilla  |
 SunFA_Cedilla  |
 s  |
 s with cedilla  |
 SunFA_Cedilla  |
 T  |
 T with cedilla  |
 SunFA_Cedilla  |
 t  |
 t with cedilla  |
 SunFA_Circum  |
 spacebar  |
 circumflex accent  |
 SunFA_Circum  |
 0  |
 degree sign  |
 SunFA_Circum  |
 1  |
 superscript one  |
 SunFA_Circum  |
 2  |
 superscript two  |
 SunFA_Circum  |
 3  |
 superscript three  |
 SunFA_Circum  |
 exclamation point  |
 broken bar  |
 SunFA_Circum  |
 minus  |
 macron  |
 SunFA_Circum  |
 underscore  |
 macron  |
 SunFA_Circum  |
 period  |
 middle dot  |
 SunFA_Circum  |
 slash  |
 vertical line  |
 SunFA_Circum  |
 A  |
 A with circumflex  |
 SunFA_Circum  |
 a  |
 a with circumflex  |
 SunFA_Circum  |
 C  |
 C with circumflex  |
 SunFA_Circum  |
 c  |
 c with circumflex  |
 SunFA_Circum  |
 E  |
 E with circumflex  |
 SunFA_Circum  |
 e  |
 e with circumflex  |
 SunFA_Circum  |
 G  |
 G with circumflex  |
 SunFA_Circum  |
 g  |
 g with circumflex  |
 SunFA_Circum  |
 H  |
 H with circumflex  |
 SunFA_Circum  |
 h  |
 h with circumflex  |
 SunFA_Circum  |
 I  |
 I with circumflex  |
 SunFA_Circum  |
 i  |
 i with circumflex  |
 SunFA_Circum  |
 J  |
 J with circumflex  |
 SunFA_Circum  |
 j  |
 j with circumflex  |
 SunFA_Circum  |
 O  |
 O with circumflex  |
 SunFA_Circum  |
 o  |
 o with circumflex  |
 SunFA_Circum  |
 S  |
 S with circumflex  |
 SunFA_Circum  |
 s  |
 s with circumflex  |
 SunFA_Circum  |
 U  |
 U with circumflex  |
 SunFA_Circum  |
 u  |
 u with circumflex  |
 SunFA_Diaeresis  |
 double quote  |
 diaeresis  |
 SunFA_Diaeresis  |
 spacebar  |
 diaeresis  |
 SunFA_Diaeresis  |
 A  |
 A with diaeresis  |
 SunFA_Diaeresis  |
 a  |
 a with diaeresis  |
 SunFA_Diaeresis  |
 E  |
 E with diaeresis  |
 SunFA_Diaeresis  |
 e  |
 e with diaeresis  |
 SunFA_Diaeresis  |
 I  |
 I with diaeresis  |
 SunFA_Diaeresis  |
 i  |
 i with diaeresis  |
 SunFA_Diaeresis  |
 O  |
 O with diaeresis  |
 SunFA_Diaeresis  |
 o  |
 o with diaeresis  |
 SunFA_Diaeresis  |
 U  |
 U with diaeresis  |
 SunFA_Diaeresis  |
 u  |
 u with diaeresis  |
 SunFA_Diaeresis  |
 y  |
 y with diaeresis  |
 SunFA_Diaeresis  |
 Y  |
 Y with diaeresis  |
 SunFA_Tilde  |
 spacebar  |
 tilde  |
 SunFA_Tilde  |
 A  |
 A with tilde  |
 SunFA_Tilde  |
 a  |
 a with tilde  |
 SunFA_Tilde  |
 N  |
 N with tilde  |
 SunFA_Tilde  |
 n  |
 n with tilde  |
 SunFA_Tilde  |
 O  |
 O with tilde  |
 SunFA_Tilde  |
 o  |
 o with tilde  |
The following compose key sequences are supported in the Greek input mode. Some compose key sequences start with accent dead keys. The abbreviation “ordfemenine” stands for feminine ordinal indicator key.
Table A–8 Compose Key Sequences in Greek Input Mode|
 Press and Release  |
 Press and Release  |
 Result  |
 semicolon  |
 a  |
 lowercase Greek_alpha with tonos  |
 semicolon  |
 e  |
 lowercase Greek_epsilon with tonos  |
 semicolon  |
 h  |
 lowercase Greek_eta with tonos  |
 semicolon  |
 i  |
 lowercase Greek_iota with tonos  |
 semicolon  |
 o  |
 lowercase Greek_omicron with tonos  |
 semicolon  |
 y  |
 lowercase Greek_upsilon with tonos  |
 semicolon  |
 v  |
 lowercase Greek_omega with tonos  |
 semicolon  |
 A  |
 uppercase Greek_alpha with tonos  |
 semicolon  |
 E  |
 uppercase Greek_epsilon with tonos  |
 semicolon  |
 H  |
 uppercase Greek_eta with tonos  |
 semicolon  |
 I  |
 uppercase Greek_iota with tonos  |
 semicolon  |
 O  |
 uppercase Greek_omicron with tonos  |
 semicolon  |
 Y  |
 uppercase Greek_upsilon with tonos  |
 semicolon  |
 V  |
 uppercase Greek_omega with tonos  |
 dead_acute  |
 Greek_alpha  |
 dead_acute  |
 Greek_epsilon  |
 dead_acute  |
 Greek_eta  |
 dead_acute  |
 Greek_iota  |
 dead_acute  |
 Greek_omicron  |
 dead_acute  |
 Greek_upsilon  |
 dead_acute  |
 Greek_omega  |
 dead_acute  |
 Greek_ALPHA  |
 dead_acute  |
 Greek_EPSILON  |
 dead_acute  |
 Greek_ETA  |
 dead_acute  |
 Greek_IOTA  |
 dead_acute  |
 Greek_OMICRON  |
 dead_acute  |
 Greek_UPSILON  |
 dead_acute  |
 Greek_OMEGA  |
 dead_acute  |
 a  |
 dead_acute  |
 e  |
 dead_acute  |
 h  |
 dead_acute  |
 i  |
 dead_acute  |
 o  |
 dead_acute  |
 y  |
 dead_acute  |
 v  |
 dead_acute  |
 A  |
 dead_acute  |
 E  |
 dead_acute  |
 H  |
 dead_acute  |
 I  |
 dead_acute  |
 O  |
 dead_acute  |
 Y  |
 dead_acute  |
 V  |
 colon  |
 i  |
 lowercase Greek_iota with dialytika  |
 colon  |
 y  |
 lowercase Greek_upsilon with dialytika  |
 colon  |
 I  |
 uppercase Greek_iota with dialytika  |
 colon  |
 Y  |
 uppercase Greek_upsilon with dialytika  |
 dead_diaeresis  |
 i  |
 dead_diaeresis  |
 y  |
 dead_diaeresis  |
 I  |
 dead_diaeresis  |
 Y  |
 dead_diaeresis  |
 Greek_iota  |
 dead_diaeresis  |
 Greek_upsilon  |
 dead_diaeresis  |
 Greek_IOTA  |
 dead_diaeresis  |
 Greek_UPSILON  |
 semicolon  |
 semicolon  |
 Greek tonos  |
 colon  |
 colon  |
 diaeresis/dialytika  |
 ordfeminine  |
 0  |
 plus-minus sign  |
 ordfeminine  |
 1  |
 section sign  |
 ordfeminine  |
 2  |
 superscript two  |
 ordfeminine  |
 3  |
 superscript three  |
 ordfeminine  |
 5  |
 broken bar  |
 ordfeminine  |
 6  |
 copyright sign  |
 ordfeminine  |
 7  |
 not sign  |
 ordfeminine  |
 8  |
 soft hyphen  |
 ordfeminine  |
 9  |
 degree sign  |
 ordfeminine  |
 hyphen  |
 vulgar fraction one half  |
 ordfeminine  |
 backslash  |
 pound sign  |
 ordfeminine  |
 braceleft  |
 modifier letter reversed comma  |
 ordfeminine  |
 braceright  |
 modifier letter apostrophe  |
 ordfeminine  |
 bracketleft  |
 left-pointing double angle quotation mark  |
 ordfeminine  |
 bracketright  |
 right-pointing double angle quotation mark  |
 SunFA_Acute  |
 a  |
 SunFA_Acute  |
 e  |
 SunFA_Acute  |
 h  |
 SunFA_Acute  |
 i  |
 SunFA_Acute  |
 o  |
 SunFA_Acute  |
 y  |
 SunFA_Acute  |
 v  |
 SunFA_Acute  |
 A  |
 SunFA_Acute  |
 E  |
 SunFA_Acute  |
 H  |
 SunFA_Acute  |
 O  |
 SunFA_Acute  |
 I  |
 SunFA_Acute  |
 Y  |
 SunFA_Acute  |
 V  |
 SunFA_Acute  |
 Greek_alpha  |
 SunFA_Acute  |
 Greek_epsilon  |
 SunFA_Acute  |
 Greek_eta  |
 SunFA_Acute  |
 Greek_iota  |
 SunFA_Acute  |
 Greek_omega  |
 SunFA_Acute  |
 Greek_omicron  |
 SunFA_Acute  |
 Greek_upsilon  |
 SunFA_Acute  |
 Greek_ALPHA  |
 SunFA_Acute  |
 Greek_EPSILON  |
 SunFA_Acute  |
 Greek_ETA  |
 SunFA_Acute  |
 Greek_IOTA  |
 SunFA_Acute  |
 Greek_OMICRON  |
 SunFA_Acute  |
 Greek_UPSILON  |
 SunFA_Acute  |
 Greek_OMEGA  |
 SunFA_Diaeresis  |
 i  |
 SunFA_Diaeresis  |
 y  |
 SunFA_Diaeresis  |
 I  |
 SunFA_Diaeresis  |
 Y  |
 SunFA_Diaeresis  |
 Greek_iota  |
 SunFA_Diaeresis  |
 Greek_upsilon  |
 SunFA_Diaeresis  |
 Greek_IOTA  |
 SunFA_Diaeresis  |
 Greek_UPSILON  |
Table A–9 Compose Key Sequences in Greek Input Mode With Three Keys
 Press and Release  |
 Press and Release  |
 Press and Release  |
 Result  |
 semicolon  |
 colon  |
 y  |
 lowercase Greek_upsilon with dialytika and tonos  |
 colon  |
 semicolon  |
 y  |
 semicolon  |
 colon  |
 i  |
 lowercase Greek_iota with dialytika and tonos  |
 colon  |
 semicolon  |
 i  |
 dead_acute  |
 dead_diaeresis  |
 y  |
 dead_diaeresis  |
 dead_acute  |
 y  |
 dead_acute  |
 dead_diaeresis  |
 i  |
 dead_diaeresis  |
 dead_acute  |
 i  |
 dead_acute  |
 dead_diaeresis  |
 Greek_upsilon  |
 dead_diaeresis  |
 dead_acute  |
 Greek_upsilon  |
 dead_acute  |
 dead_diaeresis  |
 Greek_iota  |
 dead_diaeresis  |
 dead_acute  |
 Greek_iota  |
 SunFA_Acute  |
 SunFA_Diaeresis  |
 i  |
 SunFA_Diaeresis  |
 SunFA_Acute  |
 i  |
 SunFA_Acute  |
 SunFA_Diaeresis  |
 y  |
 SunFA_Diaeresis  |
 SunFA_Acute  |
 y  |
 SunFA_Acute  |
 SunFA_Diaeresis  |
 Greek_iota  |
 SunFA_Diaeresis  |
 SunFA_Acute  |
 Greek_iota  |
 SunFA_Acute  |
 SunFA_Diaeresis  |
 Greek_upsilon  |
 SunFA_Diaeresis  |
 SunFA_Acute  |
 Greek_upsilon  |
Table A–10 Compose Key Sequences in Greek Input Mode With Four Keys
 Press and Release  |
 Press and Release  |
 Press and Release  |
 Press and Release  |
 Result  |
 semicolon colon  |
 colon semicolon  |
 semicolon colon  |
 colon semicolon  |
 Greek dialytika tonos Greek dialytika tonos  |
