XmTextFieldSetLayoutModifier() sets the layout modifier values, which changes the behavior of the layout object tied to its rendition.
The syntax for XmTextFieldSetLayoutModifier() is:
#include <Xm/TextF.h> \ void XmTextFieldSetLayoutModifier(Widget \ widgetstring layout_modifier)
XmTextFieldSetLayoutModifier modifies the layout object settings of a rendition associated with the widget. When the layout object modifier values are set using this convenience function, only the attributes specified in the input parameter are changed. The rest of the attributes remain untouched.
