The iconv command converts the characters or sequences of characters in a file from one code set to another and writes the results to standard output. Korean Solaris software includes special filters for the iconv command.
If no conversion exists for a particular character, it is converted to the underscore _ in the target code set. The following options are supported:
-f from-code - Symbol of the input code set
-t to-code - Symbol of the output code set
The following code set conversion modules are supported in Korean Solaris software. For more information, see iconv(1).
Table 6–1 Korean iconv Code Conversion Modules (ko locale)|
Easy Name from-code |
Actual Name from-code |
Easy Name to-code |
Actual Name to-code |
IBM CP933 |
ko_KR.cp933 |
UTF-8 (Unicode 3.2) |
ko_KR-UTF-8 |
IBM CP933 |
ko_KR.cp933 |
UTF-8 |
UTF-8 |
ISO646 |
646 |
KS X 1001 |
5601 |
ISO2022–KR |
ko_KR.iso2022-7 |
KS X 1001 |
ko_KR-euc |
ISO2022–KR |
ko_KR.iso2022-7 |
ko_KR-UTF-8 |
ISO2022–KR |
ko_KR.iso2022-7 |
UTF-8 |
UTF-8 |
KS X 1001 |
5601 |
UTF-8 |
UTF-8 |
KS X 1001 |
EUC-KR |
UTF-8 |
UTF-8 |
KS X 1001 |
KSC5601 |
UTF-8 |
UTF-8 |
KS X 1001 |
ko_KR-euc |
ko_KR-UTF-8 |
KS X 1001 |
ko_KR-euc |
ko_KR-UTF-8 |
KS X 1001 |
ko_KR.EUC |
UTF-8 |
UTF-8 |
KS X 1001 |
ko_KR-euc |
KS X 1001 |
ko_KR-johap |
KS X 1001 |
ko_KR-euc |
KS X 1001 |
ko_KR-johap92 |
KS X 1001 |
ko_KR-euc |
KS X 1001 |
ko_KR-nbyte |
KS X 1001 |
ko_KR-nbyte |
KS X 1001 |
ko_KR-euc |
KS X 1001 |
ko_KR-johap92 |
ko_KR-UTF-8 |
KS X 1001 |
ko_KR-johap92 |
KS X 1001 |
ko_KR-euc |
UTF-8 |
UTF-8 |
KS X 1001 |
5601 |
UTF-8 |
UTF-8 |
KS X 1001 |
KS X 1001 |
UTF-8 |
UTF-8 |
KS X 1001 |
EUC-KR |
UTF-8 |
UTF-8 |
KS X 1001 |
KSC5601 |
UTF-8 |
ko-KR-UTF-8 |
IBM CP933 |
ko_KR.cp933 |
UTF-8 |
UTF-8 |
IBM CP933 |
ko_KR.cp933 |
UTF-8 |
ko-KR-UTF-8 |
ISO2022-KR |
ko_KR-iso2022-7 |
UTF-8 |
UTF-8 |
ISO2022-KR |
ko_KR-iso2022-7 |
UTF-8 |
UTF-8 |
ISO2022-KR |
ISO2022-KR |
UTF-8 |
ko-KR-UTF-8 |
KS X 1001 |
ko_KR-johap |
UTF-8 |
UTF-8 |
KS X 1001 |
ko_KR-johap |
UTF-8 |
ko-KR-UTF-8 |
KS X 1001 |
ko_KR-johap92 |
UTF-8 |
UTF-8 |
KS X 1001 |
ko_KR-johap92 |
Wansung |
ko_KR-euc |
Johap |
ko_KR-johap92 |
Wansung |
ko_KR-euc |
Packed |
ko_KR-johap |
Wansung |
ko_KR-euc |
N-Byte |
ko_KR-nbyte |
ILEG=KS X 1001 |
ko_KR-euc |
ISO-2022-KR |
ko_KR-iso2022-7 |
Johap |
ko_KR-johap92 |
Wansung |
ko_KR-euc |
Packed |
ko_KR-johap |
Wansung |
ko_KR-euc |
N-Byte |
ko_KR-nbyte |
Wansung |
ko_KR-euc |
ISO-2022-KR |
ko_KR-iso2022-7 |
Wansung |
ko_KR-euc |
The following modules perform character-based code conversion on the KS C 5700 character set. They convert KSC 5700 characters between Korean UTF-8, completion code (Wansung), and combination code (Johap).
Table 6–2 Common Korean iconv Code Conversion Modules (ko and ko.UTF-8 locales)|
Easy Name to-code |
UTF-8 |
ko_KR-UTF-8 |
KS X 1001 |
ko_KR-euc |
UTF-8 |
ko_KR-UTF-8 |
KS X 1001 |
ko_KR-euc |
UTF-8 |
UTF-8 |
KS X 1001 |
ko_KR-euc |
UTF-8 |
UTF-8 |
KS X 1001 |
ko_KR.EUC |
UTF-8 |
ko_KR-UTF-8 |
Johap |
ko_KR-johap92 |
UTF-8 |
ko_KR-UTF-8 |
Packed |
ko_KR-johap |
UTF-8 |
ko_KR-UTF-8 |
ISO-2022-KR |
ko_KR-iso2022-7 |
Wansung |
ko_KR-euc |
UTF-8 |
ko_KR-UTF-8 |
Wansung |
ko_KR-euc |
UTF-8 |
UTF-8 |
Johap |
ko_KR-johap92 |
UTF-8 |
ko_KR-UTF-8 |
Johap |
ko_KR-johap92 |
UTF-8 |
UTF-8 |
Packed |
ko_KR-johap |
UTF-8 |
ko_KR-UTF-8 |
Packed |
ko_KR-johap |
UTF-8 |
UTF-8 |
ISO-2022-KR |
ko_KR-iso2022-7 |
UTF-8 |
ko_KR-UTF-8 |
ISO-2022-KR |
ko_KR-iso2022-7 |
UTF-8 |
UTF-8 |
UTF-8 |
ko_KR.UTF-8 |
Unified Hangul |
ko_KR-cp949 |
UTF-8 |
UTF-8 |
Unified Hangul |
ko_KR-cp949 |
Unified Hangul |
ko_KR-cp949 |
UTF-8 |
ko_KR-UTF-8 |
Unified Hangul |
ko_KR-cp949 |
UTF-8 |
UTF-8 |
In the following example, a KS C 5601 file (Korean EUC) is converted to KS C 5700 (ko.UTF-8).
system% iconv -f ko_KR-euc -t ko_KR-UTF-8ko_euc_file > ko_UTF-8_file |
For further information, see the iconv(3C), iconv_ko.UTF-8(5), and iconv_utf(5) man pages. You can use these utilities to convert files for printing.
