A locale contains the culturally specific information and conventions of the language for a particular global region. Each process in the Solaris Operating System has the following set of locale attributes:
Locale settings, which provide the locale and setlocale commands you use to list and set attributes before you start a process from the command line.
For example, the Simplified Chinese locales and the English/ASCII locale both have a category that defines the display of time and date according to the cultural format, as well as the actual Simplified Chinese or English/ASCII characters for the time and date.
Code sets, which support coding conventions for the GB2312 and the GB18030 character sets. These sets enable you to input, display, and print Simplified Chinese text in file names, system messages, and terminal (TTY), email, and data file content.
htt input method server, which handles Simplified Chinese input for the Solaris Operating System. The htt server receives your keyboard input and converts it to Simplified Chinese characters that are used in Simplified Chinese applications.
The Simplified Chinese Solaris Operating System provides simultaneous support for the locales in the following table. The locales look the same to the end user, but the internal character encoding is different.
Table 1–1 Simplified Chinese Locales|
Locale |
Description |
zh_CN.EUC (zh) |
Simplified Chinese EUC (GB2312) |
zh_CN.GBK (zh.GBK) |
Simplified Chinese GBK |
zh_CN.GB18030 |
Simplified Chinese GB18030-2000 |
zh_CN.UTF-8 (zh.UTF-8) |
Simplified Chinese UTF-8 (Unicode 3.2) |
The following table lists supported code sets for each Simplified Chinese locale.
Table 1–2 Simplified Chinese Code Sets|
Locale |
Code Set |
zh_CN.EUC (zh) |
gb2312 |
GBK |
zh_CN.GB18030 |
GB18030–2000 |
UTF-8 |
The Simplified Chinese Solaris Operating System provides input methods and fonts for the locales shown in the lists and tables in this section.
The following input methods are supported for the zh locale:
New QuanPin
New ShuangPin
NeiMa
QuanPin
ShuangPin
GB2312 NeiMa
WangMa Wubi
English-Chinese
Optional code table input methods
Input method auxiliary window support for Simplified Chinese
The following input methods are supported for the zh_CN.GB18030 locale:
New QuanPin
New ShuangPin
QuanPin
ShuangPin
GB18030–2000 NeiMa
WangMa Wubi
English-Chinese
For a complete list of fonts supported for the Simplified Chinese locales, see Bitmap and TrueType Fonts.
The input method auxiliary window supports the following functions.
