You can make a system-wide change to the default locale with the following procedure.
Become superuser.
Edit the /etc/default/init file.
Add or update the LANG variable with the appropriate locale.
LANG=locale |
You can set the LANG variable with one of the following locales: zh, zh.GBK, zh_CN.GB18030, zh.UTF-8
Instruct all users to exit CDE.
Kill the dtconfig process.
# /usr/dt/bin/dtconfig -kill |
Reboot the system.
# reboot |
