Simplified Chinese Solaris User's Guide
Setting Input Method Options
Four code table input options are available for the input method you select.
How to Select an Input Method Option
  1. Click the input method selection item from the utilities menu.
    The input method selection panel appears.
  2. Select an input method from the selection panel.
    The input method options panel appears.
    The preceding context describes the graphic.
  3. Select an input method option.
  4. Click OK or Apply to activate the selection.
