Simplified Chinese Solaris User's Guide
Printing Chinese Output From a Command Line
This section provides information that you can use to print from a command line with the lp command and the mp program.
Printing With a Line Printer
You can use the commands in this section to print files of different formats to a line printer.
    Use this command to print an EUC file.
system% lp EUC_filename
    Use this command to print a GB format file to a printer that supports GB format.
    system% lp -T GB GB_filename
